Old 12-14-2017   #1
SBAquaLT5
Default Door Decals
I have a bit of a pickle in that someone that didn't know any better painted/removed the factory driver door jamb decals including the build date and tire loading.
There are a few companies that can recreate these decals I've found, however I need to provide the build date info... I have the OEM build sheet, but I understand that is the order date, not the build date?
Can anyone share how these stickers should be placed, what they would look like on a '93, and where else I could find the build date on the ZR-1?
1993 Bright Aqua Metallic # 027
SBAquaLT5 is offline   Reply With Quote
Old 12-14-2017   #2
Default Re: Door Decals
I am interested in this as well.. I don't have mine and it would be a nice to have item
Sorry I am not much help
Old 12-14-2017   #3
I took a pic of mine 91 & 93 just in case something happened to them but have no way to post pics here. PM me your e-mail and I would be glad to share what I have, The vin# and build date will differ on yours also the recommended tire pressure changed.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 12-14-2017   #4
WVZR-1
The vendors that offer the reproductions generally require a digital image of the "old/original" before they'll supply you another. I know of no one that will reproduce one without it. maybe something "similar" but not a duplicate of the original.
Once the car leaves the dealer as a sold unit the certification label actually can't be requisitioned by the dealer. I don't believe that it's changed through the years.
I believe people have attempted "photoshop" for them and have been refused.
I've done many using this company. I actually asked (only once) if I could be accommodated. I guess when I asked I had likely had 3 - 4 dozen orders processed with a commercial account.
http://www.ecsvin.com/order.php
Old 12-14-2017   #5
SBAquaLT5
I did contact ECS vin and they said they could do it for $120 or something like that. This was before I got my build sheet. They have records of what the 90's GM cars look like, but I would rather them know for sure with a real ZR-1 tag. I have found a couple other sites that do the repro, but several have suggested ECS.
It's worth every penny to get it back on the car the way it should be, I just need to make sure I give them the right data! There's gotta be another build date somewhere on the car...
Thanks guys
Old 12-15-2017   #6
WVZR-1
Thanks guys
Take your VIN to a GM parts department and I believe when they do a SPID request it may still show the mo/yr that the certification label shows. If you ordered the build sheet from NCM then you should have gotten a window sticker also that should validate also mo/yr.
Having a '93 with the low # of builds you should be able I'd think to create the mo/yr from other references by '93 owners.
Good luck with ECS with no snapshot confirmation! Others are only similar - theirs a 'reproduction'.
