![]() Join Date: Oct 2016
Can someone please confirm if the zr1 reservoir is different to std.c4. My 90 model was in a minor accident and according to the repairer, one of the outlet tubes that the hose pushes onto is cracked. He is going to see it can be plastic welded, but if it's not, will have to get a replacement. Question; Are they available new or used?
Thanks.🇦🇺 |
![]() Join Date: May 2007
I do not know if the tank is different for the ZR-1, but I may have a Power Steering Tank (that came from a ZR-1) in the garage. I will look and let you know.
If it isn't fun, you aren't doing it right! 1990 Black ZR-1 - sold 1993 Quasar Blue ZR-1 1994 Competition Yellow ZR-1 1995 Dark Purple ZR-1 Maryland State Coordinator WAZOO Member Last edited by QB93Z; 10-20-2017 at 07:39 AM. |
![]() Join Date: Oct 2004
Reservoir needs to be LT5 but from any year. A GM part# 26017982 if you'd like to shop the "down-under" for possibilities.
![]() Join Date: Dec 2003
I have used ones in stock if you are unsuccessful elsewhere.
http://www.jerrysgaskets.com/reservo...used-90-95-6d/
Thanks guys. Even if the repairer is able to repair/weld it, l might chase up a secondhand one anyway. I'll talk to my repairer about it next week. It's comforting to know that l can source one from the USA and have shipped to AUSTRALIA if need be
Cheers |
#6 | |
I will take one of those reservoirs of your hands. I'll just work out what other bits and pieces l need from you and place the order. Freight wise, l might as well make it worth while. |
