Old 07-22-2015   #151
Default Re: Frankenplenum
Had Frank out last week.....running good....getting new Toyo Proxes TQs put on this week. Still one small oil leak(,ight be the oil sensor), but its about time to get to the dyno.
Old 07-30-2015   #152
Dyno Test 9AM Monday
http://www.dynotunemp.com/contact.html
Old 07-30-2015   #153
Good luck. Waiting to hear results.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 08-02-2015   #154
Seeing 99/100 KPA readings on my Tech one.....can't wait til tomorrow
When doing dyno runs, one thing to look at is the MAP value. This can indicate if there is restriction somewhere ahead of the intake. In the runs I have recorded on my 5.7L, kPa at WOT ~ 97-98 and it doesn't drop hardly at all after peak.
That's pretty close. I also check my KEY ON MAP signal because unless u are at sea level, your MAP won't be at 100kPa anyway.
I'm a bit skeptical like Todd but it's good to have someone like you Lee who'll test it out.
Old 08-02-2015   #155
Old 08-03-2015   #156
Lee,
Came out looking great. Excited to see the dyno results.
Old 08-03-2015   #157
I will be curious to see myself....could be anything from a loss in power to significant gains. Crap shoot....fingers crossed for tomorrow.
I left the Corsa system on for apples to apples test.
Next dyno test will be a 3" ....and finally a tune
Old 08-03-2015   #158
What was the previous result? Prior to the plenum change?
Old 08-03-2015   #159
Win some lose some; car lost power....only interesting piece was at 7400rpm the car was only down 8hp from peak.
Frank Set Up
426hp@7100
361 ftlbs
Siamase
441hp@7100
373 ftlbs
Old 08-03-2015   #160
Car was running pretty fat
11.8 to 12.46 most of the run...
11.8-12.1 from 5100RPM to 6900
