09-11-2012 | #21 |
Re: Raptor and Henderson Performance
Ron,
BTW, I am in Vegas this week, leaving Thursday am. staying at The Paris for conference. Let me know if you can come over for a drink. Dominic
09-11-2012 | #22 | |
Wow, I know the whereabouts of forum members better than that of my own kids! |
09-12-2012 | #23 |
Yep, Dubai...
Scheduled to be back on the 27th... |
09-12-2012 | #24 |
What does the base system consist of? then also what would be above that if at all? 10k doesnt seem bad for that much power being added and assuming a safe reliable tune. what are you thinking HP #'s on the single set up? Hope this all works out for all parties envolved, it makes a great addition/option to our cars
09-12-2012 | #25 |
I would be that to be a low boost $$$$. You will need to redo your bottom end and lower the compression and while your in there...etc, etc. etc...
Not sure if the $10k includes labor of any kind...
Dennis Fierstein 90 ZR-1 #2562 Atomic-Z ZR-1 Net Registry Chairman of the Board ZR-1 Net Registry Treasurer |
09-12-2012 | #26 | |
The base system contains: Stainless Steal Hot and cold pipes (CATs if needed) Turbo's Turbo Oiling system Waste Gate Blow-Off valve Electric Harness Hardware for the above Options: Intercooler Exhaust Tips Gages Fuel Pump Injectors Raptor ECM Headers Right now, only option is to have Corey Henderson install the system. I think Ron said Corey is charging $1700 for the install but I could be a little off... I'll check again The Single Turbo on a stock car should be around the same HP/TQ numbers as the stock dyno sheet above. Those numbers are from my stock 91 with twins pushing around 4 psi. All for around $5500... |
09-12-2012 | #27 | |
$10k does not include labor. FYI - I'm using the stock crank and rods on my 374. The engine builder said the stock internals would good to 1000 HP. He did however perform some lightening and stress relieving on the rods. I believe all the engine work and parts for my 374 cost around $9500 even with Ron Woods Head Studs. The goal is to eventually up it to 15 psi...
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int Last edited by RHanselman; 01-27-2013 at 07:24 PM. |
09-13-2012 | #28 |
Arrrgggg! Really wish I had the money to do this, working and going to school part time isn't leaving me any extra cash to play with. I just love the sound of whooshing turbos!
09-15-2012 | #29 |
09-15-2012 | #30 |
law away sounds good...just lay the turbos in my trunk and I will pay you in a couple years.
1994 #293 ZR-1 Stainless Works Long Tube Headers, B&B catback w/ X-Pipe, 18" Shelby Series One Wheels, SLP CAI. |
