Old 10-06-2013   #1
Default Oil separator anyone?
For those that might be interested, I picked up a very nice Moroso oil separator. It is a class act piece of equipment. It is a closed cylinder, billet aluminum, about 2.5" in diameter, x about 5" long, and comes with the inlet/outlet barb fittings at the top, the separator filtering (metal) is installed, and has a petcock and barb connector on the bottom for draining, and a billet aluminum mounting bracket. Very nice machine work.
Price was $150+tax; ready to install - just need hoses and done!
P
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 10-06-2013   #2
Schrade
Default Re: Oil separator anyone?
If this oil isn't removed with this device, where does it end up?
I'm guessing it will foul somewhere?
Old 10-07-2013   #3
Oil, not separated, makes its way to the combustion chambers, fouling plugs, carboning up the valves, contributing to knock, plugging the MAP sensor hose (leading to other seemingly disassociated issues with idle and AF mix...) Not good. The LT5 (among other open deck motors) is prone to a little more crankcase pressurization - hence oil blow-by - than some others (tho some LS motors also have oil separators for the same reason: keeping oil out of the cylinders).
I'll post a pic of the Moroso unit later.
P.
90 #1202
Sans secondaries
Old 10-07-2013   #4
P.
Paul...last time I checked my Elite Oil Catch Can after several 1/4 mile runs and some additional miles (I think it makes a BIG difference if you stand on it) I had maybe 1/2 inch of oil in bottom of Oil Catch Can. So it works
Old 10-07-2013   #5
Racinfan83
Two quick questions - does this setup eliminate the PCV valves - and if I don't run the car hard like some of you guys do (racing, etc), is it even necessary?
It does look cool - but I'm trying to keep the stock look for now...
Old 10-07-2013   #6
No it does not eliminate the PCV valves. It captures oil before it gets into the plenum etc.
Old 10-07-2013   #7
Schrade
Is there too much oil to be filtered by some sort of added-in filter membrane? Maybe for those who don't race, like FrankU says above, and do 'hammer down' once / twice per outing, only enough to get new fuel through the secondary injectors - will THAT make for enough oil to justify a catch can?
So in the existing intake hardware, where will I see excess oil when [IF] I [ever] pull the intake / plenum ?
And since it's (+) crankcase ventilation, how does it purge, to the intake vacuum? good snappics too there...
(where is emissions routing diagram in FSM - anyone know offhand here? ) IS AIR ACTUALLY FORCED INTO THE CRANKCASE, for fumes purge??? Or is it a mis-nomer?
Hmmm... positive air pressure, into the induction.
Forced-Oil Induction?
Old 10-06-2013   #8
It ends up in plenum and you burn it........but it gums up the intake more than necessary
-=Jeff=- was one of the first I think Oil Catch Can Photo
Here is what I used on both a 90' and 91'.
See Item #5 of LT5 Added Systems
See Details for Oil Catch Can Installation
The PCV hose connected under front of plenum (Vacuum source) is connected using SS braided hose to an Oil Catch Can external to the engine which Oil Catch Can is connected using SS braided hose to the dual PVC valves hard line located at the rear of the plenum. The Oil Catch Can is located on the drivers side inside wheel well (using a small channel ground and drilled to conform to the inside fender well as a spacer).
The Oil Catch Can used here is the Elite Engineering Oil Catch Can
(I use wing nuts for quick Catch Can Maintenance)
Old 10-07-2013   #9
efnfast
Is there a down side to doing this? Other than the fact that GM didn't do it originally.
Old 10-07-2013   #10
in short no..
