Old 09-09-2011   #1
Exclamation removing the secondaries a compelling story
Scope view at point of discovery the awwww Crap moment!!!!!
Folks a lot of you know I am going through a motor rebuilding process. For those of you not in the know my car engine stopped dead in late May of this year almost at idle. Preliminary checks revealed Zero compression on Cylinder #2. I am sharing this as a documented failure on my 91 for the entire community’s info.
Here was the cause. One of the butterfly valves (#2 Cylinder)for the secondary’s snapped at the shaft screw point and fell into the head into the combuston chanmber and wedged a valve open. You can cleary see the fatigue at the screw point of the shaft. Scoring was seen on both the #2 and #4 pistons. This actually happened to me before on the other side of the motor when I received a CODE 61 Error. That time the parts did not go into the motor.
IMHO the debate is over. If you are doing any headwork or motor work remove the secondary system. Blades, Rods, actuators, reservoirs etc. Who doesn’t drive our car in full power anyway?
Just FYI and I hope this helps another brother out. This is a failure point but after 20yrs there are bound to be a few. Please heed my sage advise. GC
