#31 | |
HC 1.30 FAIL But better CO 6.71 Pass but was not an issue NOX 4.30 FAIL but worse I suspect the additive Im convinced these CATS wont make it through any IM147 test. So I using another option.
#32 |
i think ryan is right about the pvc system in connection with the plugs .daryll do you have a couple of leaking spark plug tubes ,leaking oil , i had this on my white car and found that when i used the tapered plugs those plugs in the leaking cylinders were darker .they also seemed to, not be tight when i went back and cked them . i went to the standard gasketed plug and this stopped some what. till i just bit the bullet and fixed the problem . my thoughts were that oil got into the combustion chamber everytime i pulled the plugs making them darker . now with the problem fixed they all look the same .hope this in some small way helps .
#33 | |
#34 |
![]() Join Date: Aug 2006
#35 | |
1st test $36.00 2nd re-test Free 3rd test $36.00 My advise to anyone else considering long tubes is to stay away from the metal substrate bullet cats and go with the bullet ceramic cats. I think they are too free flowing and will never meet a 1.00 HC standard. My factory cats when not damaged would pass without a problem. GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-11-2009 at 03:36 PM. |
#36 |
good advise , guess i am thankfull that i dont have to test except if i sell the car .
#37 | |
Nick, right behind the collectors, I know heat was not an issue this time as the car was about at 80% band about 230. I held the car at 2000 RPMs with the AC on like FU said. I could see the heat thermals in the shadow my car was casting on the ground. Every states different I just dont think they can meet the 1.00 HC standard or the 2.5 NOX standard. Its possible its just too much motor for the cats. If I was to do it again I would go the ceramic route. I would not reccomend these to anyone, Jeffvette swears these are 100% identical to the RTs but who really knows. Its a non issue now. But I am leaving the cats in place as its the right thing to do. Thanks for all the ideas folks, at least you know these did not work for me so buy accordingly. Side note: The DRM Proms is back in and the car is happy so I am happy. I have never seen a car POWER through two exceedlingly fouled plugs and 2 suspect plugs that were loose. Its a testiment to the engine. This car is a beast that likes to be beat on. Try this with the girly cars. This is why I believe when its tuned right, it will run very very well.
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-11-2009 at 09:27 PM. |
#38 | |
![]() Join Date: Jul 2007
#39 |
Has anyone ever tried or thought to try tying in to the PCV lines with an external electric vacuum pump? could tie in to help out the PCV system or eliminate the PCV set-up all together & just run the vacuum pump directly to the engine, would be a closed system. i'm talking about, rig it up for the test, PASS, then take it off again. i dropped off an engine at the dyno i use this evening & i took an electric vacuum pump i own to use on this enigne. not sure what the customer wants to do for sure regarding elec. or mech. vac. pump, so for now i'll just use the one i have around strickly for dynoing & he can make up his mind later. when i was dropping everything off i started thinking about this problem being discussed on here the last couple days. as i've stated, emission stuff is not my deal at all, but i use vacuum pumps, electric & mechanical, on 70% of the engines i do. it makes more power when done right, proper rings, ring lands cut accordingly etc., but it also helps clean things up a lot. i've never been a fan of the PCV deal, i understand why they did, just don't like it...
#40 |
![]() Join Date: Jul 2005
GC, here are my results from January of 2008 (last time the car was tested). Car has:
Jeal headers RT metallic substrate cats Haibeck chip Stock injectors (at that time) ![]() The numbers don't seem to correspond to those you are posting, unless you remove the decimals from your numbers (or add them to mine). I do not think the metallic substrate cats are the problem with your car. Best of luck! Last edited by Nick; 03-12-2009 at 12:34 PM. Reason: spelling error |
