#21 |
Maybe put in a next step hotter plug.
#22 | |
![]() Join Date: Aug 2006
#23 | |
I have also wondered about these metallic cats and how well they work. I have to take the VA test soon, hopefully they work well enough, but I have my doubts. I wonder if swapping bullet ceramic cats in for the test would help enough to be worth it? |
#24 |
Ok update.... Went to see my friends house Fred (A forum member) heres what we looked at Fuel rail pressure about 42 Lbs Constant and holds after car shut off, Ruled out fuel pressure, surging and Injectors. Put in the stock 91 Prom. Pulled plugs on Driver side two a little loose but nice even burn on the set (Light brown). Pulled plugs passenger side two loose plugs hand tight and suspect oil fouled. Two completly oil fouled #2 and #6 exceedingly saturated, could not even see the electrode on the end of the NGK irdiums they had about 25K on them. Put in a fresh set on non Tappered flat ACs as they were all I could get my hands on. What would cause one side to oil foul before the other. Fred suspects two week cylinders or seals under camcover?
The car with the stock prom idles about 650-700 with Rippies Prom it idled about 850-900. Would the Prom and the plugs as stated be enough to hose the test? From my view it should help but would it be enough?
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 03-11-2009 at 03:27 PM. |
#25 |
Allowing the fans to come on later will help get the engine a little bit hotter, at least on the way to the test. A hot day wouldn't hurt the cause either.
#26 |
#27 | |
102K Its my daily driver Ryan. Jeffvette suspects the PCVs are part of this problem but without a doubt the valve seals are tired as well. GC
#28 |
i think jeff has hit on the problem , we too often dont pull the pvc valves and the rubber connector at the back of the motor and clean it out . i would definatly pull that and the valves and clean them just before you go . GOOD luck hope ya pass . i hate having that junk over my head
#29 |
![]() Join Date: Jul 2005
GC, where are the cats mounted? On my '94, the Random Tech metallic substrate cats are mounted directly to the Jeal header collectors. I can't believe they don't get hot enough in that location. Also, I'm running a Haibeck chip. Car has passed emissions in WA better the last two times run than it did when stock.
#30 | |
