Old 03-12-2009   #41
Default Re: Emissions retest another failure
My test is on a dyno is yours Nick? I think your state uses just and idle and cruise test. Ours runs up and down under load in a 1-6 shift point program X2 for about 10 minutes. I also think our state expresses mathmatically 150 HC as 1.5 which is your states standard and mine is 100 HC or a 1.0 standard. I believe our standards are tougher in AZ.
Also im running magnaflows vs Random Techs, they look the same but maybe a little different also DRMs tune might be different from MHs
Old 03-12-2009   #42
Nick
Yes, this test was run on a dyno. The "cruise" emissions are measured while in 4th gear.
Old 03-12-2009   #43
hmm then the standards are different plus our equipment is a little different
Old 03-12-2009   #44
Pete
Pete's Avatar
You guys still have emissions,that sucks.
No more emissions for OBD I cars in IL
I'm CAT free and loving it.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-12-2009   #45
Pete in AZ there are emissions requirements for cars from 1967 to present. Only 1966 and older and collector cars are exempt.
Old 03-12-2009   #46
jonszr1
jonszr1's Avatar
geez yours are tougher than ca. they dont start testing till 75 when cats were introduced
Old 03-12-2009   #47
rhipsher
rhipsher's Avatar
Well D. I guess its time for you to move back to Texas. Haha! The last time I got my inspection sticker on the Z it passed emissions with flying colors and I was almost out the door when the inspector tried to honk my horn and it didn't work. And he says well I can pass it if your horns don't work! I said well they don't get used very much. So he tried it again and they worked luckily. It passed every god forsaken test with every piece of electronic equipment they had while having a wond stuck up its butt. But by god they were gonna fail it over the stupid horn not honking and I'd be out $39. What a racket.
Old 03-13-2009   #48
Yeah the guy I bought it from told me how the Texas Ahem inspection stamps work.... If you have cash you pass......
Old 03-13-2009   #49
PhillipsLT5
PhillipsLT5's Avatar
Sounds like Chicago
No Emission @ Firebird Fri nite, just test&tune
You comin?
I will be there At 6
Old 03-13-2009   #50
rkreigh
VA lowered HC to 48 ain't no way.
the alchy doesn't work too well with a "closed loop" chip as the ECM compensates seeing a lean condition.
I'm going to try open loop, rich as hell pure alchy
I don't have secondaries which doesn't help either. graham told me that was one of the big reasons they went with that design was to get more velocity up under part throttle. I have another method, use your wallet. less hassle and there are many "helpful" folks that will take you that route
what I don't understand is changing the emissions laws to be tighter than the car was designed to pass in the first place. that's just wrong.
