Old 09-30-2017   #21
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Potential Fuel Pressure Regulator Solution
First round of testing was very encouraging. Before going to the trouble of pulling the plenum and swapping out the stock fuel regulator I wanted to make sure the rebuilt regulator would control fuel pressure properly and not leak so I hooked it up to a spare set of fuel rails and did some testing with it connected to the car's fuel supply and return lines:
First connected a jumper from the battery + to the fuel pump test connection to run the pumps with out the engine being started.
Tested the stock regulator with and without vacuum being applied
With vacuum 41 psi indicated
Without vacuum 50 psi indicated
Rebuilt regulator with vacuum 42 psi indicated. No problem controlling the full flow of both fuel pumps.
Rebuilt regulator without vacuum 49 psi indicated. No problem controlling the full flow of both fuel pumps.
And best of all, no leaks!
Now on to swapping out the stock regulator and doing some driving tests.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Jagdpanzer is online now   Reply With Quote
Old 09-30-2017   #22
RussMcB
Very nice.
Russ McBride, [COLOR="Red"]Car Sold 8/2020[/COLOR] #1635, Marietta, GA USA, 1991 ZR-1, #766 (bought 1/1/2015)
MS3-Pro, OBX, SW X-Pipe, Borla, Hurst, SLP, Goodyear F1 GS-D3, Kenwood. HOTB 2016Q3
[IMG]http://zr1.net/forum/picture.php?albumid=316&pictureid=2873[/IMG] [IMG]http://zr1.net/forum/picture.php?albumid=336&pictureid=2985[/IMG]
Old 09-30-2017   #23
Well done Phil I think it looks better than OEM
Old 09-30-2017   #24
Roadster
Roadster's Avatar
As always, your work is flawless.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 09-30-2017   #25
Top Toy
Top Toy's Avatar
Looks similar to the one Lingenfelter used to make. Nice work!
ATTACH]6640[/ATTACH]
Sent from my HTC U11 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167
Old 09-30-2017   #26
Phil,
If you splice in unit below, you can adjust pressure increase point.
https://www.google.com/search?q=delp...TvtBqEQgjYIyAQ
Old 09-30-2017   #27
Pete
Pete's Avatar
Very nice Phil.
Sorry Phil.
But this just caught my eye.
Dennis, WOW 468RWHP is that SEA corrected and what were the corrected torque #'s.
Have you taken it to the track 468 RWHP with stock wheels should be running 126 MPH.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-30-2017   #28
Top Toy
Top Toy's Avatar
Those results were based on Standard corrections. Actual RWHP was higher. Was a cool, dry day which always helps! Torque was about 380, corrected. Last track day was several years and several mods ago. No match for yours!
Old 10-01-2017   #29
Phil.....I have at least one Fuel Pressure Regulator that has failed and am saving that so I can use a Delphi FP10023 once you have proven the concept.
I assume your machined ring is outside the Delphi flange and if you were to sell those machined rings I could use that as a template to drill and tap threads for the Allen Head machine screws
How did you remove the present Fuel Pressure Regulator Mechanism from the Aluminum Housing so as not to damage the compatibility of the Delphi to that original Fuel Pressure Regulator Housing?
Your research is superb and if this works out and you were to sell the machined rings I am in for at least 3
I will pay a premium if you tell me how deep to tap and provide the screws
All kidding aside (I am not kidding about the machined flanges).....Phil....this is great research and your machining capabilities are the best....
Thank you for all your contributions over the years
Old 10-01-2017   #30
Jagdpanzer
Jagdpanzer's Avatar
Cliff,
Thank you for the compliments. Im afraid the retainer ring by itself won’t do you much good. The stock regulator body requires several machining steps to adapt the Delphi FP regulator. Once I’ve finished testing ths one I will be tweaking the machining steps a little to make it easier to reproduce which will likely impact the retainer ring design.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
