11-19-2013 | #71 |
Re: Locobob's Interior Mod Thread
LMAO @ mike
that was good
11-20-2013 | #72 | |
11-20-2013 | #73 |
Yep no argument
11-20-2013 | #74 |
Ah now that sounds much better than jacking the car and trying to squeeze up to the switch which appears to be near the bell-housing. I'll poke around and see if I can find it. If not then perhaps I will just run another wire along the back-up cam route since I can readily see and access the LT green wire through the license plate hole.
11-20-2013 | #75 |
When I installed my back-up camera, I used a extra wire with the camera wire. Hooked it up at the back-up light, behind the license plate. Haven't looked back since. Or have I? I'm confused.
91 ZR-1 Red on Red #922 |
11-21-2013 | #76 |
So I think I have found the easiest route to connect the reverse wire off the head unit to the back-up light circuit. Here it is under the passenger dash, this should be C209 as it matches the connector description in the FSM electrical supplement.
The back-up lamp circuit is a LT green wire, at first I was a little confused since there are two wires here which appear to be LT green but another look at the FSM indicated its terminal F on C209 so it should be the one at the top of the pic. I probably could have run a wire all the way back to the reverse lamps in less time but by doing this research I found a super close spot to plug in and also learned a lot about the FSM in the process - thanks WVZR-1
11-21-2013 | #77 |
And learning to follow schematics in FSM is good brainwork too. Makes for good systemic and cognitive processes!
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] |
11-21-2013 | #78 |
Its not there yet, probably get that done today.
11-21-2013 | #79 |
Bob sorry I missed you latest post however if you have a Varible Speed Sensor wire on your head unit the VSS wire is the Forrest Green Wire with the White Stipe off the Bose factory radio harness. Normally you need this wire if you have a NAV unit and dont want to rely on dead reackoning. D
11-21-2013 | #80 | |
