Old 12-31-2008   #1
Robm3
Default Code 31, what's the impact of it? (2 problems actually)
Hi,
Problem #1. I'm getting a code 31 on my LT5 which is the Cam Shaft sensor but it doesnt seem to be effecting the running of the motor at all.
I've not done the testing as to if it's an ECU fault or not but just wondering what the impact of this would be on day to day running ('spose it's just a slight lose of power).
Problem #2 My Power Mode is working intermittently, getting power through the Valet Switch okay but the second row of injectors just aren't firing up consistantly. I'm wondering if the issue is related to problem #1
Any ideas?
Thanks Lads.
Robin
(PS the engine is actually in an Ultima GTR)
Robm3 is offline   Reply With Quote
Old 12-31-2008   #2
Jeffvette
Default Re: Code 31, what's the impact of it? (2 problems actually)
Robin, code 31 is for the Cam Sensor. The electronics use the sensor to sync up the ignition with the crank. When it is not working correctly, the SES light comes on, and then the injection system is firing in "batch" mode. This would be the reason why your secondaries are not working.
Possible causes:
Faulty Ground
Faulty Connection
Bad ECM
Bad Cam Sensor
Old 12-31-2008   #3
Robm3
Possible causes:
Faulty Ground
Faulty Connection
Bad ECM
Bad Cam Sensor
Right then, I have the manual and it says to check the ECU when running to see if a current is coming through (Brown plug, pin 3 from memory). Can I pull the whole 'Brown' plug when the engine is running though? or do I need to just take out pin 3?
The manual then says if there is a fluctuating current coming through it's your ECU that's the issue.
I'm hoping there's no current then as I'm guessing a sensor or connection is an easier fix. Anyhow I'll have a play around with it tomorrow.
Thanks for the info Jeff
Old 12-31-2008   #4
Jeffvette
Unplug the brown connector first. Then probe. With the brown connector unplugged the vehicle will not start. Do not unplug it with the vehicle running.
No problem.
Old 12-31-2008   #5
Robm3
No problem.
Jeff,
Sorry to be a pain but just to be sure,
step 1. unplug the brown plug and connect probe
step 2. then turn the engine over?
Presume it won't start as you say but will show a reading?
Manual is a little unclear as it says 'test with engine running' naturally that's a little tricky if you can't unplug the brown plug when running although can always 'splice' into the wire and test.
Old 12-31-2008   #6
Jeffvette
What book are you using?
Step 1:
Engine idling is code 31 present
If yes
Step 2
Ignition off
Disconnect brown connector
Probe D3 for voltage
Crank engine
Did DVM display 0-5 volts
Step 3
Ignition off
Disconnect cam sensor
Connect test light between terminal A & C of harness
Ignition on
Is test light on
Step 4
Connect test light between A and ground
Is test light on
Old 12-31-2008   #7
Tyler Townsley
Long ago when mine threw a 31 it was the ECM not the sensor. You might have to borrow an ecm to check it out.
Tyler
