Old 09-30-2007   #1
mimzr1
mimzr1's Avatar
Default Fuel pump assembly
Howdy! Is there a magic trick for pulling the fuel pump assembly out without bending or breaking something?
mimzr1 is offline   Reply With Quote
Old 09-30-2007   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Fuel pump assembly
Easy job, check out:
http://mywebpages.comcast.net/zrjuan/sender.html
http://zr1netregistry.com/Old_Proj/old_proj11.htm
http://zr1netregistry.com/fuelpump.htm
Old 09-30-2007   #3
It's mainly a trial & error, lifting, turning & leaning the assy until it comes out. Primarily be concerned with the float & float arm to not bend it. The snags are mostly due to the plastic hose clamps & the big "latching mechanism on them. I replaced mine with small, worm-screw clamps, placing the screw more towards the interior of the assy to prevent hanging up going back in. Went in a lot easier than coming out.
Old 09-30-2007   #4
4DSZR1
4DSZR1's Avatar
Originally Posted by A26B
...I replaced mine with small, worm-screw clamps, placing the screw more towards the interior of the assy to prevent hanging up going back in. Went in a lot easier than coming out.
Good tip!
4DSZR1 is offline   Reply With Quote
