View Poll Results: Which Brand of spark plug you run?
Autolite 3 2.10%
AC-delco 68 47.55%
Accel 1 0.70%
E3 4 2.80%
Champion 0 0%
Bosch 11 7.69%
Brisk 0 0%
Torque Master 1 0.70%
Motorcraft 0 0%
NGK 45 31.47%
Pulstar 0 0%
Splitfire 1 0.70%
Denso 9 6.29%
Voters: 143. You may not vote on this poll
Old 09-22-2008   #1
HADI-ZR1
Default Which Brand of Spark plug do you run??
Please Let us know what plug you run, and your opinon about it.
most Spark plugs in the poll have part number for Zr-1.
What I use now is Torgue Master Spark plug, it is the same as BRISK PREMIUM LGS. I use them more than 1 year with NO fail and the lt5 become more aggressive than before and still...
the picture is here:
Old 09-22-2008   #2
jonszr1
jonszr1's Avatar
Default Re: Which Brand of Spark plug do you run??
i am currently using the e3 in the callaway and the new bosch ultimate in the 90
Old 09-22-2008   #3
Aurora40
Aurora40's Avatar
NGK iridiums
Old 09-22-2008   #4
HADI-ZR1
My next test would be Brisk DOR15LGS!
here the email i got from BriskUSA and i post it here for info. exchange!
With nitrous we recommend heat range Brisk 14The measured gap is about 2.5 mm. However LGS style plug is a semi-surface discharge plug that requires significantly less energy to jump the gap than standard plug. This plug works well in applications where recommended standard gap is .8mm and up. The stock ZR1 use DOR15LGS, if modified or nitrous you should use DOR14LGS or DOR14LGS-T ( a version with reduced gap for high compression, forced induction or nitrous applications).
Best regards,
Chris
http://www.briskusa.com/images/GMHighTechMagazine.pdf
Old 09-22-2008   #5
Pete
Pete's Avatar
I use AC Delco plain jane resistor plug i think it's 61-402 gaped at .035
I'm not a big believer in maricle plugs or snake oils,unless somebody has real proof any of the snake oil,plugs make more power i will stick with AC Delco's.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-22-2008   #6
Z Factor
Z Factor's Avatar
Originally Posted by Aurora40
NGK iridiums
Same here
Old 09-22-2008   #7
I was trying to run down an intermittent stumbling problem when I replaced my plugs with the platinum AC/Delcos. The stumbling turned out not to be the plugs, however.
That said, I'm happy with the performance. But, I don't think I would go "platinum" again. My research since then leads me to question the value of the longer life touted by platinum in my specific application (read: street driven and no full-out racing to speak of).
Plugs in a street driven car degenerate in a more or less linear fashion - in 3 phases, if you will: At first they are good, then so-so, and then there is that phase where they work but really need to be replaced.
The difference between the standard plugs and the platinum plugs is the length of those three phases...and of course the initial cost. So, I've concluded that the standard plugs are cheap enough and they're easy enough to replace on the LT5 that I can afford to replace them regularly enough to keep the plugs in that "new" phase. (That said, platinum plugs cost about the same as a tank of gas. So, replacing them every 5+ years...is no biggie either way, I recon.)
Different applications dictate different plugs. Those that autocross or drag race a lot would have different ideas than those like me, I'm sure.
Old 09-22-2008   #8
RedSled
AC-Delcos
- Keith
RedSled is offline   Reply With Quote
Old 09-27-2008   #9
I'm sure that there are better plugs than the GM replacement for the FR2LS plugs. I just feel that buying the regular 61-402's @ .35", and throwing them out every winter isn't killing me cost wise. I would even believe that the 402's aren't really a direct replacement for the 2ls's.....but the 402's seem to work real well for 5k miles at least.
Old 02-09-2009   #10
White Bullet
White Bullet's Avatar
AC for me. They are easy enough to change out if need be.
White Bullet is offline   Reply With Quote
