Old 03-14-2024   #1
scorp508
Default WTB: 94-95 ZR-1 Center Gauge Cluster Bezel (aka Radio Bezel) w/ Power Key
My '94 ZR-1 had its secondaries system deleted and the center gauge cluster bezel w/power key has been replaced with a non-ZR-1 version. While I won't be adding the secondaries back, I'd still like a power key + bezel to retain one of the unique things about the ZR-1.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
scorp508 is offline   Reply With Quote
Old 03-15-2024   #2
dredgeguy
dredgeguy's Avatar
Default Re: WTB: Center gauge cluster bezel w/power key.
Contact Mark at Mirrock Corvette www.MirrockCorvette.com He might have one for you.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 03-15-2024   #3
scorp508
Good idea thank you, I reached out and will see if he has anything.
Old 03-15-2024   #4
scorp508
Mirrock does not currently have any.
Old 03-15-2024   #5
scorp508,
Finding a 94 or 95 "Dulso" coated radio bezel with power key slot and white lettering in good condition is next to impossible. Even a brand new one in a box by now would have become gooey.
I ended up buying a GM OEM replacement radio bezel finished in satin black paint, drill a hole for the key and a slot for the green light (very carefully), JB Weld mounting posts on the back for the 2ndary power key module and replicate white lettering with matching font vinyl lettering. Trust me, it's not as easy as it sounds and take some steady hands.
I stripped Dulso off the shifter console and sprayed with Testor's flat black paint for plastic models and the finish is a near perfect match between two pieces.
Success rate is about 40-60. I ruined a couple of both pieces to get one of each in satisfactory finish.
Not easy but can be done.
https://www.gmwholesaledirect.com/oe...=free_listings
