![]() Join Date: Dec 2023
I have three ACDelco PF970 (no C) filters (blue). They are new, in the box and in good shape. They must be 20+ years old. Any issues in using them?
Thanks. |
![]() Join Date: Aug 2006
I think you would be fine.
The oil flows through the outside first ( the small holes ) & back out through the centre hole......
Check for any corrosion and especially look into the center hole with flashlight and see if anything is loose that would flow into the engine. If the box is tight and no corrosion.....I concur with secondchance ![]()
![]() Join Date: Sep 2008
