![]() Join Date: Aug 2021
3rd owner, never been in the rain or parked outside. Still has the lot sticker taped in the front window from Andersen Chevrolet in CA, and we also have the sales (build) sheet. 7,340 miles. Excellent condition inside and out. Listed below is what I've done to the car and finished the project 8-1-21. ALL parts are OEM or equivalent:
New cooler hose kit (oil lines) from the oil filter to the oil cooler; New fuel pressure regulator; New fuel injectors; New air inlet duct; New fuel regulator vacuum hoses; All of these items above are from Jerry's Gaskets. New braided S.S. brake lines from the tube to the wheel; New brake fluid; New metal brass gears for headlight rotation (work great); New spark plugs; New spark plug wires; New serpentine belt; New thermostat; New set of 6 original coolant hoses; New set of 12 original hose clamps for all 6 hoses; New petcock assembly; New coolant; New PCV valves (2); New fuel filter; New oil filter and oil (engine); New oils in transmission and rear end; Greased entire chassis; New air filter; New tires - Nitto-Motivo for wet/dry - these tires just came out in 2020; All four maintenance manuals from Chevrolet. This car is as clean inside as it is underneath. Any questions call Steve - 253-310-5142. Asking $45,000 - OBO Last edited by Beaver's 90ZR1; 06-11-2022 at 03:44 PM. |
![]() Join Date: Sep 2008
VERY nice!
GLWTS! ![]() Marty |
thank you
