Old 07-12-2020   #1
Vette73
Default Weak fans inside car at highest setting.
Not that I use my AC much, if at all..Still at setting 10 on the fans the stream of air is very weak....Any way to improve this ? Or its not operating correctly..??
Old 07-12-2020   #2
Default Re: Weak fans inside car at highest setting.
Marc has run a new wire to run parallel to the original which made an improvement. I have manual AC and I am working on a plan for the same however GM ran wires back and forth across the car so it not as simple.
Old 07-12-2020   #3
Has it always run weak? Is there any difference between 1, 5, and 10 setting? It could be fan control module.
Old 07-13-2020   #4
lfalzarano
I just had the same issue this week.
Old 07-13-2020   #5
dredgeguy
dredgeguy's Avatar
In stock configuration mine had 10mph air flow out the vents. After Marc did the 200 amp alternator upgrade and double wired to the AC fan the output was measured at 14mph. Huge improvement in air flow for cooling and heating.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 07-13-2020   #6
lfalzarano
Marc is a long way from Clayton, NC[emoji20]
Old 07-13-2020   #7
Mine are weak also.
Old 07-13-2020   #8
Vette73
Tell you the truth I believe it always has...Only used the AC a few times and that was on long trips with a lot of open roads..
I will check the fan control module...
Old 07-13-2020   #9
if it varies, then I doubt it is the module..
Old 07-13-2020   #10
I followed suit and also installed 200 amp hair pin alternator along with a pair of Spal fans, extra 8 ga. Wire between the alternator and the battery plus 14 ga. between the battery and the HVAC module. Combination of extra cooling of ac condenser and extra oomph at HVAC condenser, it felt nice and cool even in 96 degree day in DC. This is with glass top.
