Old 01-31-2020   #1
Flyman 27
Flyman 27's Avatar
Default New key availability
Just went to ACE Hardware to get a spare key cut with the #3 resister for my replacement column I installed.
The lady behind the counter cautioned me that I need to have any keys I want cut very soon. ACE will no longer be ordering any VATs related key blanks. When their stock runs out, they will be no longer available.
So if you need a spare key, and you buy at ACE like I do, I would not recommend snoozing, you better get while the getting is good.
[SIGPIC][/SIGPIC]
Cams by Pete
Old 01-31-2020   #2
Default Re: New key availability
No worries... Several locksmiths have VATS keys still, AND I recently had one made for Ami's car at the local GM dealer (which also had a reader that would spit out the key blank (pellet) number.)
Attached is a chart with the VATS key blank numbers, arranged according to resistance ranges. So, with you VOM, read the resistance between the metal contacts on the VATS pellet and compare it to the chart to get the # and either a dealer or (most?) locksmiths can make you a spare.
Old 01-31-2020   #3
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
Jesser's will likely always have them.
You can still get nearly every Corvette and other keys.
Even sells knock outs!
I am sure they cost more than ACE though.
Marty
Old 02-07-2020   #4
jw63
jw63's Avatar
I think I saw replacement VATS keys on Ecklers for ~$9.00 or so. Seemed like a decent price.
'90 #413 Red/Red Sold
'90 #1583 Red/Red
jw63 is offline   Reply With Quote
