Old 08-14-2018   #1
Route 66
Route 66's Avatar
Default Tech 1 or Tech 2
Looking for members who have knowledge of these scanning tools. If you have used ether of these would you post the pros and cons of them. I do not know much about ether one. I am thinking I should get the Tech 2. From what I have read it can be used on the 92 to 2010 vetts' I am having a problem with a 93 ZR1. Not getting the 405 HP and not throwing a engine DTC code. I have no vacuum leaks so it must be electrical. I repaired a vacuum leak under the plenum and while under there I made sure the actuators were working.
Thanks for your input.
Route 66 is offline   Reply With Quote
