![]() Join Date: Nov 2016
My climate control panel shows only 3 dashes (---) and does not respond to input, other than for fault code reading. Though no codes show. Fan blows constantly to windshield when ignition is on.
Having attempted some fixes (headunit eraser/cleaning and programmer capacitor replacement) without the desired success, I've started glancing for a replacement while the fault finding continues. I notice the Z programmet have a different part number, which naturally makes it 3-4 times as expensive. Why? Can I not use a programmer for a regular C4? Any hints on where to acquire one that does not cost $700?
- '90 ZR-1 |
#2 | |
![]() Join Date: Mar 2014
http://www.zr1.net/forum/showthread.php?t=25372
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 02-14-2017 at 10:03 AM. |
That was the first thing I tried, but I appreciate the input. The buttons respond fine when I activate the trouble code programme (hold up+down for 5 sec), but the head unit does not show temperature, nor indicate mode with the diodes.
Looks like this (borrowed pic) ![]() It's the exact same issue as this guy had. http://www.digitalcorvettes.com/foru...d.php?t=118406
- '90 ZR-1 Last edited by S.hafsmo; 02-14-2017 at 10:28 AM. |
![]() Join Date: Dec 2007
Maybe some moister or water got on to it?
You would probably have to check out the FSM for that one....Don't know if you own the Service Manuals for your year, but that would be a very good investment. I will take a look at my FSM and see if I can find anything for you. And there may be another member who have experienced this problem and respond....
The circuit board in both the programmer and headunit looks mint, even the cardboard on the back looks good. I've checked the FSM, but offcourse I was missing the 8A electronics supplement. Was really hoping to see an obvious defect when I opened it, but no such luck
- '90 ZR-1 |
This is what I found, and you may also found the same....
From the FSM.... "The computerized HVAC programmer receives input from several on-vehicle sensors, the CCM, also temperature and mode requests from the HVAC control head." "The information input to the HVAC programmer is processed and used to control the electronic automatic HVAC system. Three sensors, specific to the electronic automatic HVAC system provide input to the HVAC programmer." 1-OUTSIDE AIR (AMBIENT) TEMPERATURE SENSOR 2-INSIDE AIR TEMPERATURE SENSOR 3-SUN LOAD SENSOR I could not find any info on a non-functioning LCD display with or without the 3 dashes (---). Could it be that one of the sensors or the CCM is defective, therefore causing you not to get the reading on the LCD and thus the system not operating properly??? Thinking logically, the sensors mentioned and or the CCM may need to be checked out for proper operation...
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1974 L-82 355 Vert. 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member Last edited by Roadster; 02-14-2017 at 11:16 AM. |
![]() Join Date: Oct 2004
See 1C1-22 for a '90 (CODE 10 or ---) If year other than '90 the ERROR CODE should be found on a similar/close to page. The failure isn't likely internal to the C68 control.
***If you don't have an FSM or maybe just not the 8A which is relevant here drop me an email. I can do a .pdf complete that is way better than most, both books, the '90 - '93 LT5 supplement a couple parts SPO publications that I had done for me professionally. We can do the FSM via "DropBox" and you can have same day paid PayPal. I've done many. My .pdf is searchable and you can clip images and sections of text from it that most .pdf can't. |
#9 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director ![]() 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 02-14-2017 at 12:25 PM. |
#10 |
![]() Join Date: Feb 2013
I had this problem on my MY90 several years ago so this info isn't fresh in my mind but I called Gordon Kilebrew and we were able to resolve it. One of his tricks was to remove the blower motor resistor from the heater box. That allows you to look at a flapper that directs air to different positions. As I recall his advise was to remove and replace the battery cable and that causes the flapper to cycle and reset. His concern was that at least on MY90s was that the only thing to stop the flapper was the small tab that stops rotation had probably broken. Apparently repairing a faulty flapper is a royal PITA. Luckily for me it rotated and stopped as it should. From there we determined that the HVAC controller was the problem. I found one on eBay and I don't remember that it was a zr1 specific part. It is beside the steering column behind the hush panel and in its own right it is a PITA to replace. That did work for me and all these years later I've had no more issues. Gordon said that if the head unit doesn't see the return signals that it expects it just locks.
Like I say this if I went through this five days ago instead of five years my memory might be better but I do remember Gordon originally was concerned that the flapper just going around and around. Hope this helps. Sent from my iPhone using ZR-1 Net Registry |
