Old 03-14-2017   #1
msuhanek
Default Oil Usage
My 91 ZR-1 uses about a quart every 1100 miles or so. 62k miles. No leaks or oil smoke I see. Plugs are clean. Any ideas or concerns?
msuhanek is offline   Reply With Quote
Old 03-14-2017   #2
Vetman
Vetman's Avatar
Default Re: Oil Usage
Sounds pretty normal for a z. Depends a lot on how often your foot is in it.
1990 Z # 2441
1959 c-1 230 HP 4 speed frost blue/silver 3 owner
2011 cts-v 556 HP, manual 6 speed
1955 chev 2dr ht PP 265 3 speed w/OD
Vetman is offline   Reply With Quote
Old 03-14-2017   #3
I concur as does depend on your foot and may depend on what oil or grade of oil you are using.....which is??
Old 03-14-2017   #4
Hib Halverson
Only the 90s, because they had no exhaust valve seals, have a reputation for abnormally high oil use under "normal" conditions.
At 62,000 miles, I'd say that 1100 miles per quart would be just over the high-side "normal" if the engine is using a good 10W30 synthetic and is subjected to a normal duty cycle.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 03-15-2017   #5
TealZR1
Yes, like most of us foot is mashed much of the time for the fun of it. The car runs 10 W 30 synthetic. At this point of it's life. Should I run 10W-40 or 20 W 50? Thanks for your help!
TealZR1 is offline   Reply With Quote
Old 03-15-2017   #6
Hib Halverson
"Foot mashed much of the time" means to me that you run the engine hard. If that's the case, with that mileage, I wouldn't worry about 1000 miles per quart.
I'd stick with 10W30 unless you experience sustained high oil temperatures, say...above 250°F. If that's the case, go to a 10W40.
I've had great luck with Gibbs Driven DT40. It's actually a 5W40 and, nowadays, I use it in all my Corvettes.
Hib Halverson
Technical Writer
Old 03-15-2017   #7
efnfast
It seems like the first quart goes away very quickly. Leave it down a quart, as long as your not road racing, you should be ok. Don't forget, it has 12 quarts in it.
Old 03-15-2017   #8
My experience is that in normal driving I hardly l used any oil in either my 93 or 95. On my trips down to Bowling Green (about 450 miles each way) I showed no oil consumption for the whole trip if we did not do any actual racing. When we went drag racing or did some hard laps on the NCM track I consumed about half a quart more than without it. So having your foot in it does seem to make a difference -Bob
Old 03-15-2017   #9
TealZR1
With the LT5 and 61,000 miles, would it be OK to run a 10 W 40 or 20 W 50 oil possibly to reduce the oil consumption? Thanks for everyone's help!👍
Old 03-15-2017   #10
Mystic ZR-1
Mystic ZR-1's Avatar
GM said 10w-30, but what do they know?
