Hi guys,
I'm hearing a weird sound from my rear left, whenever the car is under way and being stopped. Going forward is worst than going reverse, sorry I couldn't get a better video than that. The faster I go before stopping, the worst it'll be. Any idea? Sounds like a blow off valve from a turbo car. https://www.youtube.com/watch?v=QgVtzH-C6XQ |
Jack up the rear and see if it changes.
![]() Join Date: Feb 2012
Cold bushings?
I can't jack up the car and go forward or reverse!
![]() Oh that might be! Was cool outside that day, only drove the car for a couple of hundred feets or so to store it inside. Will check it out next month (I'm gone at sea). |
![]() Join Date: Jun 2015
Did you check you fan to see if there is something loose? I had a sound like that once on a different car and then I lost a blade on the fan, it went through the radiator BTW!
