Old 11-01-2016   #1
90_ZR1
Default New ZR1 owner-timing & sparkplug question
I just got my first ZR-1 (1990) last week and drove it for the first time this evening.
It doesn't idle too badly, but misfires badly when driving. My first question is what sparkplugs are recommended. I pulled one plug and it's an AC Delco 41-800. I saw another post where someone had 41-620's.
I would also like to know if the timing is adjustable, and what it should be if so.
Any advice appreciated.
90_ZR1 is offline   Reply With Quote
Old 11-01-2016   #2
Default Re: New ZR1 owner-timing & sparkplug question
Timing change needs to be done by modifying the calibration.
Old 11-01-2016   #3
90_ZR1
Ok. Is that something which you can explain?
Old 11-01-2016   #4
PhillipsLT5
PhillipsLT5's Avatar
Probably injectors problem
Old 11-01-2016   #5
zrfast1
You need special tooling and expertise to interface your computer chip (prom) which is your ECM brain. Hope that helps
zrfast1 is offline   Reply With Quote
Old 11-01-2016   #6
Welcome, most all your questions can be answered here.
http://www.zr1.net/forum/showthread.php?t=16778
look at post 3, coils and plugs
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 11-02-2016   #7
90_ZR1
Thanks for the input guys!
Old 11-02-2016   #8
Timing is likely not ur issue.
Old 11-03-2016   #9
henryr
mine has a slight and / or occasional miss 2-3k....
not sure if the car has the stock injectors or not at 26k miles
going to order a set of new injectors as the plugs look okay
henryr is offline   Reply With Quote
Old 11-03-2016   #10
PhillipsLT5
http://www.zr1specialist.com/HAT%20W...in%20Place.pdf
