![]() Join Date: Jul 2015
I have a 1991 ZR-1 with the first generation (375 HP) LT5 engine with 36,000 miles on it. I noticed now that upon starting, a significant amount of bluish white smoke emits from both tailpipes for a few seconds and then dissipates. It is not water vapor. No smoke has been observed when driving, though. Associated with this issue is a significant increase in oil usage, I calculated 1/2 quart per 600 miles.
Advice has been given that this could be worn valve guides or valve seals allowing oil into combustion chambers. Any thoughts on cause or diagnostics that can guide me to proper repair would be greatly appreciated! |
low miles but prob the valve seals and guides as stated since you stated the oil consumption as well. This is something normally confirmed after the tear down. GC
I would make sure the PCV system is working. Any oil in the corrugated intake/Air Horn?
Thanks for the help, gentlemen. I will check the corrugated air intake and air horn for oil ASAP.
Marc Haibeck on oil consumption
Seems you are average on oil consumption if you are driving it fairly hard. If you are just cruising then maybe a bit much on oil consumption. As an example, I just drove 2,000+ miles with 95' and did not use any oil. there was about 4 tablespoons of oil accumulated in my oil catch can ![]() ![]() Sent from my iPhone using ZR-1 Net Registry
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 08-27-2016 at 02:48 PM. |
![]() Join Date: Mar 2004
Its normal for an early LT5. They didn't have exhaust oil seals.
![]() Join Date: May 2011
![]() Join Date: Feb 2011
#10 |
![]() Join Date: Jun 2015
The OP did not state how long he has owned the car, so this may be a problem he inherited from the previous owner or a new problem that just surfaced. It would be good to know. I think he should do a compression leak down test. Checking the PCV system is good start IMHO, you might get lucky and avoid the leak down test.
