Old 06-19-2016   #1
Johnny5
Default tire pressure monitor question
i most likely need a new tire press sensor as the genius mechanic broke it when i got a new tire put on. the service LTPWS came on for the 1sr time and it was working it told me i had a flat. can i buy a generic one on amazon or i need a speicific corvette one? its a gm part heres the link. He is fixing this!
https://www.amazon.com/s/ref=nb_sb_n...ressure+sensor
Johnny5 is offline   Reply With Quote
Old 06-20-2016   #2
lisounds
lisounds's Avatar
Default Re: tire pressure monitor question
I believe you can only use the gm corvette specific ltpws
and each location has its own designated color
I found this hope it helps
Make sure all of tires are over 25 psi when cold.
To examine Low Tire Pressure Warning error codes.
Turn the ignition On.
With a piece of wire connect pin 5 to pin 6.
The Service LTPWS indicator bulb will flash code 12 three times then any codes three times when
all codes have been displayed code 12 will flash three times again.
Example code 12 would be flash pause flash flash, longer pause any trouble codes like 23 would be flash flash pause flash flash flash etc...
Code 23 Orange sensor right rear reporting low pressure
Code 33 Yellow sensor left rear reporting low pressure
Code 43 Green sensor left front reporting low pressure
Code 53 Blue sensor right front reporting low pressure
Code 24 Orange sensor bad
Code 34 Yellow sensor bad
Code 44 Green sensor bad
Code 54 Blue sensor bad
Code 99
Sets if the receiver control module does not receive any wheel sensor signals for three
consecutive 30 minute periods with the ignition in the On position.
To clear the codes turn the ignition Off.
With in 10 seconds connect and disconnect pin 5 to pin 6 three times.
The diagnostic connector is located above the driver right knee.
lisounds is offline   Reply With Quote
Old 06-20-2016   #3
mike100
This is an excellent opportunity to remove the rest of the sensors.
Old 06-20-2016   #4
RICHARD TILL
Year model? Which wheel? Broke the band or the sensor itself? I have a couple from a 90.
Old 06-21-2016   #5
Johnny5
1991 zr1, left rear sensor. I had a tire patched from a construction staple and now my service light when on! the 1 thing I can't do myself and something goes wrong, it pisses me off so much. I don't want to get rid of them as they actually work and the light told me my pressure was low bc it was a small leak and i didnt notice it so it comes in handy. 25 yr old sensors still work, that is until i let this guy patch my tires
Old 06-21-2016   #6
8cam
I got rid of mine, have 4 for a 1990 just sitting on the shelf. I'd sell them cheap.
Old 06-23-2016   #7
G8nightman
G8nightman's Avatar
Here you go http://www.ebay.com/itm/89-92-Corvet...5UKbpX&vxp=mtr
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 06-23-2016   #8
When buying NOS wheel sensors off eBay be careful who you get them from. There's a scumbag selling these as NOS but they are in fact used. Ask me how I know.
Old 06-24-2016   #9
Johnny5
I dont think
Its even worth it $500 for all new sensors my tire guy told me the batteries die and you cant replace them do it seems like a lost cause once they go. Sorry to hear you got screwed over
Old 06-24-2016   #10
Originally Posted by Johnny5 View Post
I dont think
I've never seen these at new $500 a set. As stated 26 years and they still work,not too bad for a battery.
