Old 05-26-2016   #1
Mystic ZR-1
Mystic ZR-1's Avatar
Default Gas Tank Vacuum
Seems like there's a lot more vacuum then normal
when removing the gas cap? 1990 w/40k miles
No codes, runs fine. Always has passed emissions where they check
gas cap as part of check.
Fuel level in tank makes no difference.
None of the hoses/wiring etc have ever been messed with.
Just replaced fuel pumps, but it did this previously.
Gas cap?
Evap cannister solenoid valve?
Imagination?
Old 05-26-2016   #2
BigJohn
BigJohn's Avatar
Default Re: Gas Tank Vacuum
Gas cap?
Imagination?
Air temperature and air pressure!
What is kind of scary is when the fuel blows out with air pressure change!
It happens just not often!
Old 05-29-2016   #3
If you disconnect the Fuel Rail Fuel Lines, ALWAYS remove the gas cap or you will get a continue dripping of fuel out of the fuel lines as long as they are disconnected from the fuel rail.
