Old 02-17-2017   #1
Default Operational Engine Stand Set Up Complete
This be my next project to set up an Operational Engine like the guy on Ebay.
...........found this on Ebay for sale and seemed reasonable with only 23,000 miles on Engine/Trans.
Old 02-18-2017   #2
efnfast
Default Re: Operational Engine Stand Set Up Complete
Aaaaaand, what are you going to with that?
efnfast is online now   Reply With Quote
Old 02-18-2017   #3
RodB
RodB's Avatar
How about the fastest Soap Box Derby racer in town???
RodB is offline   Reply With Quote
Old 02-18-2017   #4
Good Question
I just never seen an engine for sale ready to fire up on the pallet you receive it on (with Oil Cooler and engine gauges Installed).
Including complete wire harness and gauges installed (all you have to do is add Engine and Trans Oil).
I will add Radiator and functional 1990 drivers seat and air cleaner
I will not include the steering wheel as shown unless I do want to make a Soap Box Derby Racer
Test Stand.....
ECMs,
Radiators,
Oil Coolers,
Thermostats,
O2 Sensors;
All Engine Sensors which are now easy to get at,
Clutch Components,
Gauges including,
.....Engine Oil Pressure,
.....Tachometer,
.....Alternator,
.....Oil Temperature,
.....Coolant Temperature,
I cannot figure out why he has the steering wheel and the full size fuel tank?
He does not include a radiator or mufflers but does include a functional thermostat (at least until the thermostat opens at 180 deg F).
Looks like a clutch pedal and Brake pedal and throttle.....not sure why a brake?
Old 02-18-2017   #5
Good way to hold the ignition cylinder/key?
Already made to use the stock dual fuel pump sender.
I wondered about that too
or mufflers
we don't need no stinkin' mufflers
Maybe the radiator wasn't any good, so they just left it out?
No serpentine belt either which means no AC or PS!!
Im still trying to figure out how that whole apparatus is going to ship
Old 02-18-2017   #6
bdw18_123
Would probably have to go freight on a semi-truck trailer. You'd probably have to have a forklift on site at delivery to get it off the trailer. Someone with a large enough flat bed or enclosed trailer might be able to do it, but that pallet looks pretty damn wide.
Old 02-18-2017   #7
Mystic ZR-1
Mystic ZR-1's Avatar
Looks like all it needs is wheels.
Could simplify delivery?
Old 02-19-2017   #8
george1945
There are no mounts holding the engine or transmission. Would be 1/4 that size if it were on a welded frame on wheels.. why all the controls? Is someone jerking our chains? A mad scientist perhaps.
george1945 is offline   Reply With Quote
Old 02-19-2017   #9
ssrszz4
Just plain Goofy
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
Old 02-19-2017   #10
billschroeder5842
billschroeder5842's Avatar
I feel bad for the donor car.....
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
