Old 11-07-2006   #1
Artic93
Artic93's Avatar
Default creeking suspension
I checked to see if there were any posts on this I found none. My 93 with 14K on it has some pretty good creeking in the suspension when you turn the wheels at slow speed or you pull in to a incline...this must just be a simple lubing problem right?
jason
Artic93 is offline   Reply With Quote
Old 11-07-2006   #2
40th#381
Default Re: creeking suspension
You need to get under the car with some rubber lube in a spray bottle
and spray up those rubber bushings.
Jan
40th#381 is offline   Reply With Quote
