Hello, it's me again
![]() i have one question : when i start my Z, the engine smoke for about 5mn to 10mn and then its ok it happens often when the car stayed for a certain amount of time without moving is it normal ? here is a pic from where it comes (left part of the engine) ![]() and a video http://youtu.be/qG_aVo_l6C0 Thanks |
How many miles on the car? How is the oil consumpton ?
it has 19000 miles
didn't notice abnormal oil consumption yet i add a little sometimes |
![]() Join Date: Mar 2007
There is a nut/stud that holds the header on that is leaking oil, needs to be resealed....only other issue might be cam sensor seal is leaking
![]() Join Date: Apr 2004
Header bolt or cam-cover? has to leaking on the exhaust manifold. Have you gotten up under it and done an inspection?
did a quick inspection and i didn't saw leak but i had nothing to lift the car to verify more closely
![]() Join Date: May 2011
Lee can help you with the cam cover emblems.
i've ordered the emblems from jerry gaskets already
The header stud leak can be deceiving it can run down the header....
#10 |
