Old 11-10-2013   #1
Torchred96
Default Good news and bad news. tach fixed...
While I had my engine down to replace the lifters I sent my tach cluster to be repaired. Total cost 50 bucks..maybe a little more with shipping. Turned out to be some kind of resistor that is calibrated at the factory which starts to break down after a while.
And, I replaced the pcv hoses, and my idle is back to normal..OH, and I finished powdercoating the cam covers and got the new ss bolts all over....Man does it look great sitting in my garage.
But unfortunately, there's bad news:
I started the motor up after getting it back together (probably over a year) but unfortunately, the 16 lifters on the driver's side didn't solve my knocking problem. I let it run a couple minutes to be sure. The ticking went away maybe 30 seconds as the lifters filled with oil after startup (i had primed the engine with oil) but the knock remains as before. Major Bummer.
Looks like it has to come down again. I just hope my crankshaft is okay and it turns out to be a piston end.
It was a calculated risk. I was hoping that the lifters were going to solve the issue. Hopefully I can get the exhaust off to pull the motor. I'm pretty sure the exhaust bolts will be snapping off (aft the cat) as I tried to turn them when I was under there to see what I was in for, then decided to stop and just put the lifters in.. sorry , just venting.
Boy I wish I would have bought that short block with 27k miles on it....but unfortunately, I had convinced myself it was only lifters. Oh well. wish me luck
Torchred96 is offline   Reply With Quote
Old 11-10-2013   #2
alnukem
Default Re: Good news and bad news. tach fixed...
Where did you get the Tach calibration done?
Old 11-10-2013   #3
Torchred96
the name is John and his email is j t a n d j u d y g at aol dot com take out the spaces of course. He seems to do a lot of c3 cluster repairs but did a great job on mine.
Old 11-10-2013   #4
Is it a tick or knock?
Old 11-10-2013   #5
Torchred96
definitely a knock..i meant that the tick from the lifters pumping up after I changed them. but as soon as they quieted down, the knock was pronounced.
Sounds like someone hammering on a piece of leather inside the engine. dull knocking noise...oh well
Old 11-10-2013   #6
Have you removed oil pan and inspected the bottom end...checking all rod bearings? Maybe a stethescope on the oil pan.......Assume you have good oil pressure....
Is there another thread where your issue was discussed before you changed lifters?
I am assuming this knock continues after the engine is warmed up maybe gets worse as oil gets thinner?
Old 11-10-2013   #7
I have lifter tick in my 90, would never describe it as a knock....could it be something else. bad coil, flywheel...rod knock often shows up on a scanner as engine knock.
Old 11-10-2013   #8
SteelBlueZR1
I know I am stating the obvious, but just in case... What about a slight engine misfire causing the dual mass flywheel to knock? My car's bad fuel injector caused a knock that was so convincingly bottom end engine related anybody would have concluded the engine needed be rebuilt. Do yourself a favor and use a stethescope or similar device (if you haven't already) and confirm this knock is in the bottom end vs. the clutch knocking.
SteelBlueZR1 is offline   Reply With Quote
Old 11-10-2013   #9
Torchred96
Oil pressure is great..new filter and about 60psi if i saw it right..i didnt so much look at the number as i was just making sure it had pressure to load up the bearings and lifters etc. Yeah guys I've been thru this about a year ago and you all gave me good advice...I was just hoping it was the lifters. I had the injector knock before and those were all replaced and it ran great. I haven't put a stethescope under the oil pan. When I had the pan down, I tried to move the connecting rods, and I didnt see any obvious movement except longitudinally..which seems like that would be a normal thing (sliding on the journal).
No metal (chunks) were found in the oil pan and i didnt do any kind of oil analysis...dont even know where i would have done that.
serpentine belt was off at startup so no accessories to blame..didnt run it long just enough to know it wasn't going away.
Yes Steel I had all those noises before and they all largely went away with the injector change out. But this is really much more pronounced and also it gets worse with revs..the flywheel knock was only at idle when it was missing. This noise doesn't go away...EVER
I saw a utube video about a straw in the sparkplug hole to find tdc and then pushing down on the piston after tdc on the down stroke to find slop in the rod. I don't know if that test will work because i don't think its a straight shot to the piston ..at an angle from the sparkplug i think.
Old 11-11-2013   #10
Pete
Pete's Avatar
Just wondering do you think maybe it's piston slap.
Some of our Z's have piston slap which is nothing to worry about,some are more pronounced/louder then others.
One way you can check rod/main bearing put a scanner on the car
rev it in neutral and check to see if it pulls timimg,this works most of the time depending how bad bearings are.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
