Old 05-03-2013   #1
carter200
carter200's Avatar
Default Group buy on anti-hood prop failure piece
Recently many have complained about the hood props falling down do to wind, bumping, etc. Well, no longer will you have to worry about the hood falling on your head. CT Machining has manufactured an item that gaurantees that the hood will NOT fall if you use the item they have invented. The item is made of 6061 T6 aircraft aluminum and fits in your pocket. You will be proud to own and display this item.
There will be a group buy running thru next Thursday for the "Hood Prop Stop"
The price is $15 (delivered to BG) and $18 shipped. You asked for them and they are now here. Thank you, Carter
PS: Minimum order of 15 to have them delivered to BG......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 05-03-2013   #2
scottfab
scottfab's Avatar
Default Re: Group buy on anti-hood prop failure piece
On my 90 there is no notched area on the lower tube.
Is that necessary for the piece to fit?
Scott
Old 05-03-2013   #3
carter200
carter200's Avatar
Scott,
I see the notch you are talking about and your rod may not have the notch but the rod has to sit on top of the bottom tube and this item will still work just fine.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-03-2013   #4
vettn71
Can't see the photos
vettn71 is offline   Reply With Quote
Old 05-03-2013   #5
I'm in Carter that's 1
Old 05-03-2013   #6
carter200
carter200's Avatar
Thanks GC. Knew I could count on you...........
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-03-2013   #7
902066
The hood prop looks nice , I'd like to have one. I'm not going to Bowling Green, and I don't have Pay-Pal. How do we do this? Thanks.
902066 is offline   Reply With Quote
Old 05-03-2013   #8
carter200
carter200's Avatar
I'll PM you the paymetn info.......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-03-2013   #9
carter200
carter200's Avatar
5 of the 15 needed ordered so far. Thanks to all who ordered and to those who are about to do so.......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 05-03-2013   #10
I am already in for three hood props.....GC....you need more ZR-1s
Just wait untill I show Carter my Billet Aluminum Fuel Line Clamp
