Old 07-14-2006   #1
rkreigh
Default ZR-1 Garage Sale
alot of this stuff is getting hard to find. can bring anything prepaid to carlisle to save shipping charges (except wheels, sorry)
all parts plus shipping.
I need to move this stuff out, make me an offer!!
New Bill Boudreau C 4 Beam plates - $140 (shipping included, 3 sets)
95 Bilstein FX3 shocks with Actuators and controller box, $950 (some leakage, still good 51K miles)
new complete hoses secondary vacuum hard lines “nylon spider”, $125
95 stock ZR-1 fiberglass springs with mounting hardware, $350 (front and rear, will separate)
90-95 starter motor (from 95 used, works fine, 51k miles), $125
Sway bar end links, $35 (dibs from a gent at carlilse)
Air injector smog pump, $50
Rear package tray, $5
Jeal Chip for 93-95 (for headers, ported top end) $125
stock 95 valves w/retainers $250 (13k miles)
stock 95 crank shaft (13k miles, with bearings for inspection) matched pistons w rings/liners/rods $1100
95 crank with bad journal (will turn for "mini stroker") $250
2 pistons with rods/liners - best offer
Used ZR1 LT5 spark plugs wires (52k miles, good condition) - $175
stock shifter $50
front rotors $60 per pair
radiator $95 (checked, not a ZR1 rad, LT1 auto, will fit and work fine but not correct)
93 ZR1 Sawblade rims with RA1 race tires (100 miles), $1100
93 Sawblade rims only $800
RA1 Tires only $500
93-95 Memcal, (for downloading your tune), $45
Battery support tray $25
Air valve and plumbing $75
battery blanket $10
neg battery cable $5
front spring brackets/bolts $25
used lifters (93-95, 12k miles) $200
valve assembly #1997222 (new) $25
throttle body plate $15
rear package tray foam $15
updated 8/2
Please email me @ ron_kreigh@hotmail.com if you have questions or PM me. thanks!!!
