Old 12-22-2012   #1
alwayscode390
Question 4 cam , but always called DOHC ( dual cam ) ... please explain ---
This is definitely a newb question, but I am curious why the engine says "4 cam" , but I always see people refer to this engine as DOHC ( dual overhead cam ). Dual = 2 ... see my confusion? HAHAH
I am sure there is an easy answer, thanks for the time and help ... I will be researching a lot when the holidays pass , right now work is SLAMMED!!! ---
Old 12-22-2012   #2
gbrtng
gbrtng's Avatar
Default Re: 4 cam , but always called DOHC ( dual cam ) ... please explain ---
tell us what code390 is first ... Oh what the h3ll, two cams per head, two heads per engine.
Old 12-22-2012   #3
alwayscode390
Is that typical of the DOHC engines to have 2 per head, not just 2 per engine?
Thanks ---
Old 12-22-2012   #4
DaveK
That's what DOHC means - Dual Over-head Cam - 2 cams "over" the head. If it were an inline engine it could still be DOHC and only have 2 cams, on a V - 2 heads, 2 cams per head i.e. 4
If an engine only had one came per head it would be a SOHC - Single overhead cam engine. This was the set up on the Jaguar V12 for example which the LT5 designers "borrowed" quite a bit from.
Dave
1991 #1516 Black/Black
davidmkelly.com
Old 12-22-2012   #5
alwayscode390
OK, that makes sense ... I think its the "over" the head that got me ---
Old 12-22-2012   #6
Blue Flame Restorations
Ok, what's code390 mean??????
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 12-22-2012   #7
captcorvette
If memory serves when I was in the Cop business it was radio code for Drunk or under the influence but not violent. Perhaps he is making a play on words that he likes the sauce a bit?
captcorvette is offline   Reply With Quote
Old 12-22-2012   #8
Fully Vetted
Fully Vetted's Avatar
It's also the diagnostic code for Rheumatic fever...
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 12-22-2012   #9
USAFPILOT
USAFPILOT's Avatar
SOHC engines are out there too
Old 12-22-2012   #10
scottfab
scottfab's Avatar
It's all over my head
Conventions are like that. They may be obtuse but many are.
I'd like to meet and talk to the guy that decided Feb gets 28 or 29 days but other months have 31. You'd think they'd be split differently.
Ah, conventions. I would have made it
DOCC - double over cylinder cam
or
QTCC - quad total cam count
or
THFC - two heads four cams
or
or
or
Scott
