![]() Join Date: Feb 2009
Well my 90 passed the Nazi state of Virginia's Emission's test with flying colors (Thanks Phil!!!). One more test in 2014 and I am done with this emissions nonsense!!
Rich
![]() ![]() Join Date: Aug 2005
Congrats, Rich!
I know what a weight off your shoulders this is. Can you tell us what the requirements were and what your car "blew"? Was this idle and under load (rollers) also visual check? Just comparing to CA. Thanks, Ted PS: The requirements are tougher now than when the Z was brand new. And per my tester, the Z's requirements are tougher than those for brand new cars. ![]() PSS: I also remember Locobob telling us Washington or Oregon also has a decibel test! Again, ![]() Last edited by tf95ZR1; 11-19-2012 at 12:25 PM. Reason: Wanted 2 |
#3 | |
Ted, Yes, they have a visual test to ensure air tubes and such are present. The test is on rollers under load, at 15 MPH and 25 MPH. 15 MPH HC ppm 48, reading was 15 CO % 0.19 reading was 0.00 NO ppm 632 reading was 531 25 MPH HC ppm 53 reading was 15 CO % 0.28 reading was 0.01 NO ppm 614 reading was 612 Rich
![]() Join Date: Feb 2011
That Nox would have failed the CA enhanced test regions (zip codes in the larger cities).
Needs to be just under 500 ppm. |
Wow, and your car blew a 15 HC!
Drool, Drool. ![]() That's were mine had probs. Mine blew about 40, max CA was 35 I think. New cars couldn't make 35: that's how CA is trying to get "old" cars off the road. Did you add any fuel additives? Custom Chip?] |
#6 | |
Rich
![]() Join Date: Aug 2006
Fantastic! Great to hear...
Congrats!!!!
I'm dreading my last emission test myself.... Thank god I don't have to deal with va emissions anymore! Glad it went well for you. ![]() David |
![]() Join Date: Jun 2005
Apparently VA and CA are similar in the hardware used for testing but the difference comes in the max limits of various pollutants.
For LT5s, the real problem is Nox. Unless the engine's cam profiles or cam timing has been altered such that there is misfire at low engine speeds, other pollutants are usually not a problem. Nox however, can be troublesom, especially with the 90-92 engines which do not have EGR. The 93-95 engines, with EGR, can be recalibrated to turn the EGR on at a lower speed such that the 15 mph is nearly as clean as the 25 mph. |
#10 |
![]() Join Date: May 2007
Congratulations Rich. I know that you put a lot of thought and effort into preparing your ZR-1 for the test.
Well done. Jim |
