![]() ![]() Join Date: Feb 2010
Compressor doesn't seem to kick on and the fuse in the fuse box is good.
??????? Blew ice cold last time I used it.
![]() Join Date: Aug 2009
Did you run the diag on the AC head unit for error codes?
1990 ZR-1 #642 |
mine **** the bed a week or so ago.
![]() Not yet. I'll try to get to it this week. Gotta be something simple.
![]() Join Date: Jul 2007
pull battery cable for 5 min.. then reattach and try
![]() Will do. thanks, Jeff.
can also just pull CTSY fuse, easier than disconnecting battery. Will have same effect of resetting HVAC control head.
#8 | |
Thanks, Andrew. ![]() Hopefully, it will be that simple to figure out. Then, I need to figure out what caused it.
Well, you might want to check for codes in the control head first, before you clear everything by resetting it.
If it was working fine, and now is not, it either means you've had a catastrophic loss of refrigerant charge, or there's an electrical problem. Could be as simple as a bad low pressure switch (cycling switch), but probably need to get some gauges on the system before trying to troubleshoot further. |
#10 |
Finally got to dig into the issue.
LOW ON FREON Added sealant and freon and I'm back iin the cold. Thanks for the input guys!
