![]() Join Date: Jul 2005
ALCON,
Over the last few months I've been working with the MegaSquirt Guys (http://www.diyautotune.com/). These guys's produce aftermarket DIY ECM's along with aftermarket production ECM replacements. Long story short is they are going to produce a run of 10-20 ZR-1/LT5 ECM's with their newest technology. The amazing part is they say they can utilize all of our existing electronics to include the BCM. Here are some specifics: Much better injector resolution 8 ignition outputs (provides the option for a LS1 style coil per plug) I/O. for Nitrous control (stage or progressive), water meth control, electric water pump and numerous other devices can be controlled The valet mode switch can likely be retained. The plan is to offer switchable tables, which can be user defined. Examples could be "Emissions check" mode for you guys in CA, high power vs lower power (similar to original valet mode), pump gas vs race gas, or pump gas vs E85. For turbo cars, another option could be low boost vs high boost. This can be user programmed. The unit will contain an SD slot so you can data log without your laptop. You'll have USB connections to connect your laptop for easy tuning! Here are a few of the objectives: The unit will be housed in a very similar looking ECM box with the correct connectors enabling you to just plug in your existing harness. NO CUTTING, PINNING or SPLICING! I've also asked them to look into bypassing the DIS module. This may indeed be doable which would add an entire new benefit to this system. Here are a few of the benefits as I see them: Tune-ability Upgradability Availability (of both the ECM and DIS modules) Ability to have better NOS, Meth and Boost Control Flexibility What's next?... Development... The development phase is going to take around 3 months. After the initial development I will send an ECM to each of our tuners for evaluation and testing. My ultimate goal is to have them available by the Las Vegas Gathering which is the first weekend in Oct. How to get one: I'll be distributing them through our tuners and Jerry's Gaskets. Price - Still to be determined Opportunity: I need a car for development. These guys are just north of Atlanta GA. I can ship them my car but it makes better sense if one of our members that are close buy can offer up theirs. It needs to be a car that has little to no mods. They would need your car for up to three months. We can discuss terms if anyone is interested. Cheers, Ron
Ron Hanselman Founding Member #80 CM Lifetime Member #1093 1991 #383 Twin Turbo 1993 #099 Ruby, Jeal 368 w/Snake Skinner body 1961 White with Red Int Last edited by RHanselman; 05-20-2012 at 11:52 AM. |
![]() Join Date: Mar 2007
Nice.....can you ballpark a price...I am assuming this may be 3K or more
![]() Join Date: Nov 2011
I could be persuaded to give up my car for a few months if the deal is right. It is a 91 with no mods and 52000 on the ticker. I am in SLC, UT. Let me know if this is of any interest to you.
#4 | |
Corey says that he has to charge $1000 just to wire an aftermarket unit in that won't do half as much. Especially when it comes to the BCM integration. I looked into the Big Stuff 3 which is a great system but by the time you buy the extra fuel injector harness and all the sensors, trigger wheel and computer I was in the $4500 range before installation. $2k is a much better... Cheers, Ron Last edited by RHanselman; 05-20-2012 at 03:43 PM. |
#5 | |
Thanks for the offer though... Are you going to make the Vegas Gathering? Cheers, Ron |
Absolutely!! Can't wait.
#7 | |
![]() Join Date: May 2005
Both Tod and I am having problems getting good driving manners with our packages. Mine 396 stage 2 cams extreme PnP, his 427 with even more exterme PnP and wilder cams. I know I would be interested in a plug in system with the software that is already avaiable for the unit. I am currently running dual wbo2 just to try and get the dirveability right. Woud not mind being a genny pig. Tyler |
#8 | |
While I think this would be a great system for you I need to start with a car that's mostly stock. Do you also have a stock car we could use? BTW - I didn't put it above however you can either WB or NB O2's with this thing... Cheers, Ron |
Im surprised Dom hasn not jumped on this one yet. I remember a LS1 coil experiment a little while back. The bypassing the DIS is very intruging as is a SD card input
#10 |
