Old 05-07-2012   #1
Blue Flame Restorations
Default TPS Connector Replacement
Learned something this weekend about the TPS (throttle positin sensor).
My car had one with a broken snap tab for holding the connector to the TPS. Evidently, the voltage would not stay consistent due to the broken snap tab. The car ran "ok" but had developed a small "burbble", I call it. You could feel it and hear it in the exhaust. It started last Friday. It had ran 100% after the engine work and it really dis-appointed me to have what felt like a "miss".
After discussing it with Pete, we determined that the connector with the missing snap tab may be the issue. I ordered a new pigtail from O'Reiley's and spliced it into the harness today.
Walah! Runs like a champ. The cams sound amazing and the exhaust tone is smooth, although pretty loud. I have pretty good neighbors and hope to keep it that way. The B&B with X pipe eliminates me from sneaking into or out of anywhere. LOL
With the age of our cars, and plenum pulls, disconnecting and re-connecting, it's really no surprise that this happened on my car. Plastic gets brittle, sepecially in a heated environment.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 05-07-2012   #2
4-cam
Default Re: TPS Connector Replacement
Great information, I need to replace mine as well.
4-cam is offline   Reply With Quote
Old 05-07-2012   #3
scottfab
scottfab's Avatar
Do you recall the O'Riley part # ?
Scott
Old 05-07-2012   #4
VetteMed
Better option than cut and splice, is to get a pin release tool, to allow you to reuse the stock wires and pins in a new connector housing. These tools are sold as a 3-pack, I think I paid about 9 or 10 bucks from jeg's a while back.
Tool and bare wire with pin:
pin inserted into tool, almost to the point where locking tabs are depressed.
Obviously you can't see this when the connector is assembled -- but the process is the same.
Old 05-07-2012   #5
VetteMed
http://www.jegs.com/i/JEGS+Performan...10769/10002/-1
Old 05-07-2012   #6
VetteMed
http://www.oreillyauto.com/site/c/de...tion+connector
Old 05-07-2012   #7
oricale
YEP me too..!
oricale is offline   Reply With Quote
Old 05-07-2012   #8
BWD
PT300
If I had known about the tool, I would have refrained from splicing the wires and heat shrinkng them.
Old 05-07-2012   #9
Pete
Pete's Avatar
The OE pins go weak/break.
The 2 i had were broken/weak pins.
It's not the plastic plug that makes contact it's the pins and if they're weak or broken you can change the plug and still have the issue.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 05-07-2012   #10
VetteMed
Good point. I had many connectors with brittle, cracked plastic, but no problems with any broken pins.
