Old 03-24-2012   #1
Route 66
Route 66's Avatar
Default I NEED A ZR1 FUEL PUMP
Looking to buy a new fuel pump. Anyone know of one for sale. I would like to buy the complete unit. Thanks...E
Route 66 is offline   Reply With Quote
Old 03-25-2012   #2
RHanselman
RHanselman's Avatar
Default Re: I NEED A ZR1 FUEL PUMP
http://jerrysgaskets.com/store2/root...roducts_id=575
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1961 White with Red Int
Old 03-25-2012   #3
454 suburban pumps
Old 03-25-2012   #4
DaveK
http://zr1netregistry.com/ZR1_techtips.htm #13
Repairing bad Fuel Pumps.
The ZR-1 uses two fuel pumps, a primary and a secondary. If one goes bad then you have to replace the whole assembly at a cost of around $1400. Instead you can replace the individual bad fuel pump for a cost of around $72. The '96 Suburban with the 454 engine uses the same fuel pump and is a direct replacement. GM part number is 25163473.
1991 #1516 Black/Black
davidmkelly.com
Old 03-25-2012   #5
NOT $1400 from Jerry's Gaskets. I'm traveling at the moment, but we sell that complete unit for under $350. Comes with to gasket. Drop in deal.
Old 03-25-2012   #6
DaveK
Great news Gerry! I just copied the info from the main registry site - apologies for the "misinformation".
davidmkelly.com
Old 03-25-2012   #7
RHanselman
RHanselman's Avatar
Originally Posted by RHanselman View Post
Hummm... didn't the link work?
Old 03-25-2012   #8
works for me
Old 03-26-2012   #9
Hammer
Hammer's Avatar
Talking Re: I NEED A ZR1 FUEL PUMP
PM sent.
Old 03-26-2012   #10
However you should decide to go, I would recommend replacing the plastic hose clamps with SS worm clamps. Turn the screw to the inside to make it easier to place through the tank filler neck. There have been isolated cases of the original plastic clamps coming loose.
There are other good reasons to replace the assembly, besides pumps; new level sender, hoses, clamps and new filter socks. I have had never bought a replacement pump that had the long, wrap around suction filter like the original, which required reusing the old one.
I've done both, aftermarket replacement pumps & the complete unit. All in all, I have not had a problem with either. You do have viable options to either method. Just offering objective differences for your consideration.
