Old 02-21-2012   #1
limey
Default How do you get a 1993 antenna to work on a 1990?
Anyone know?
limey is offline   Reply With Quote
Old 02-21-2012   #2
Default Re: How do you get a 1993 antenna to work on a 1990?
I did this last year. Early antennas have external relay whereas later antennas have internal relay. I had to look at the electrical schematic but basically I cut the wires going to external relay on 90 and connected directly to later version antenna - can't remember wire colors though...
Old 02-21-2012   #3
368zr1
368zr1's Avatar
Disconnect the negative battery cable.
At the antenna relay located under the center hatch trim panel disconnect connector C1 a 3 pin plug with the following wires.
Pin A Orange wires (Hot all the time) connect to Orange wire 93 antenna.
Pin B Pink wires (Hot in ACCY or Run) connect to White wire 93 antenna.
Pin C Black wires. Connect to Black wire 93 antenna.
Braided ground wire goes from antenna case to car frame.
There are a bundle of Black wires that don't connect to anything and act as a ground plane.
368zr1 is offline   Reply With Quote
