Old 01-04-2012   #1
Socalerv
Default Throttle Body Corrosion Repaint
Has anyone had success repairing and repainting the corrosion found on the throttle body adjacent to the plate?
Here is my thought going forward.
  • Remove plate ( any tricks as they should be corroded)
  • Tape off affected are for sanding and overspray
  • Sand affected area of corrosion and clean
  • Fill in recessed area with paint glaze
  • Sand smooth, clean, clean
  • Paint with Lingenfelter LT5 paint (rattle can)
  • Repalce plate with new from ZR1 member and new gasket from Jerry's.
Probably need new bolts, where can I get them?
Socalerv is offline   Reply With Quote
Old 01-04-2012   #2
Default Re: Throttle Body Corrosion Repaint
Recommend you either bypass the TB, or block the coolant at the IH ports. Unless you're drive in sub-zero weather, you will not need TB heating, and the never-ending corrosion issue. Hasn't corroded again since!
As for screws, I got mine at Ace Hardware.
Just a thought.
P.
Old 01-04-2012   #3
Socalerv
Are there "How To's" to bypass the coolant to the throttle body?
Old 01-04-2012   #4
Two ways to do it: the bypass or plugging. Either will work, but plugging allows you to remove some plumbing, and bypassing can be done without removing the plenum.
Bypass:
Remove the two curved rubber hoses that lead to the TB from connections on the plenum, and replace the two short tubes with a longer piece to connect the two plenum connections together. (The driver's side is a small elbow pipe between the #1 & 3 cylinder runners. The passenger side is a "T" connection.)
As for routing, some route the hose out and under the plenum, attaching it to the coolant cross-over pipe that is there. Or, some run a rubber hose under the plenum to connect the two IH connections together. Either will work.
Plugging off the coolant passage:
This requires removing the plenum to access the little coolant passages in the IHs that route coolant up through the plenum (to the afore mentioned connections). Drill and tap the holes and place an aluminum pipe plug, wrapped with Teflon tape.
Mine happens to be brass (aluminum would be better in the long run). Anyway, you can see the hex-hole'ed plug in my IH. That's there to shut off the coolant to the TB (one on each IH).
There is a line on the passenger side that comes up from the reserve tank area, runs along the plenum rail to the "T" connection on the passenger side of the plenum. Follow that rubber line back under the reserve coolant tank area, cut it and plug the hose (I used a metal shank from a bolt, wrapping the hose with a worm-type hose clamp and tie-wrapped it out of sight.) Remove the excess plumbing...OR DON"T! (I left the plumbing in place - gives the the motor more of a stock look. The choice is yours.).
A couple nice benefits for cutting off the coolant to the TB, in addition to the corrosion problem:
  1. The plenum runs significantly cooler! Not a bad thing when trimming 1/10ths of your ET.
  2. It can be argued too that the cooler temps could prolong the life of the DIS module (fastened to the plenum). Certainly won't do it any harm not to run so hot.
  3. You never have to fuss with draining and re-filling the coolant before removing the plenum. It cuts considerable fussing around off, next time you need to get under the plenum for something. (AND, there WILL be another time...trust me)
Hope this helps.
Oh, if your wondering about the runner diameters being uniform, instead of the primary being smaller, it is because mine has the "FBI 500" package applied to it. hence the uniformity of the runner diameters.
P.
Old 01-04-2012   #5
PhillipsLT5
PhillipsLT5's Avatar
http://zr1specialist.com/HAT%20Web/p...t%20bypass.htm
Old 01-04-2012   #6
Originally Posted by PhillipsLT5 View Post
I did the Haibeck bypass but there was just no way I could get it to come out the other side so I pulled the plenum,tweeked the bypass line to fit the way I wanted it too and put everything back together.When I had the plenum off for some reason I stripped just the top surface and painted my TB.I need to paint it again once I paint the TB to match my Carter TB plate.You cant find the screws anymore,maybe Jerrys got some.The TB plate in there now most likely is stuck,might break like mine did,good I had an NOS piece in my stash.
Old 01-05-2012   #7
Socalerv
Was the plate stuck, or bolts seized or both??
Thought of soaking with PB or WD40 before I attempt the removal. Probably get another plate from Carter.
Old 01-05-2012   #8
carter200
carter200's Avatar
Got some in stock right now.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 01-06-2012   #9
Get another plate from Carter. They are pure ZR-1 jewelery!!!! Your girl will love you for it too!
Sorry for the shameless plug for Carter, but he does the sweetest machine work this side of Mars! Oh, Hi Carter!
If you want to stop the corrosion and retain the coolant flow you need to get rid of all the white powdery stuff. I used a brass brush + WD40 for most of it. Then I used acetone + paper towels. Then I used 1000 wet to make nice nice. Then, and I think this is the important part after removing all the white stuff & the pox marks. You have to coat the new gasket on all sides and the holes for the screws. Reason is to insulate the two metal parts and the screws from the coolant. It's electrolysis that causes the pox. Two dissimilar metals in contact with water ( coolant ) and in the presence of an electric current ( block is ground ). If you interrupt that circuit you're good to go. I did that to mine back in 05 when I did my injectors and it hasn't been back since!
Old 01-06-2012   #10
carter200
carter200's Avatar
Plug away my friend......plug away. The truth will set you free
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
