![]() Join Date: Jan 2004
Players' getting ready to change Transmission & rear end Fluid. What fluids should I use?
Manfred E.......... ![]() 91 #906 http://pnwzr1.net |
![]() Join Date: Dec 2004
zfdoc says Castrol TWS 10w-60 full synthetic. It can be bought at the local BMW dealer only & it comes in Liters only. You need 2.2 liters to do the change.
I bought it from this guy the last time as the local BMW dealer is not easy for me to get to. http://www.velocitymotorcars.com/castrol.html btw, it's motor oil for an M5. The rear gear I used Mobil 75w-90 full synthetic plus one bottle of GM posi additive. If you use GM gear oil then use two bottles of posi fluid additive. Or you can use Amsoil sever duty fluid plus one of their posi additive bottles ![]() Tom
1990 ZR-1, Black/grey, #2233, stock. ZR-1 Net Reg Founding Member #316 & NCM member Last edited by tomtom72; 01-31-2011 at 05:18 PM. |
Should the transmission & rear end fluids be changed based on mileage only or should they be changed after a certain number of years as well? I have a 10k mile '94 and my Chevy dealer said not to worry about it.
After being in there for 17 years I would change both just for the sake of peace of mind.
#5 | |
#6 | |
http://zfdoc.com/faq.htm You can make an educated determination once you have the necessary information. I used his research to determine what my change intervals would be going forward and my car was a one owner car with 7400 miles on it when I bought it back in 12/04. ![]() Tom
