Old 12-06-2010   #1
Default Need Technical Data; cam timing, balancing, etc.
Fill in the yellow blanks
I could sure use some technical data regarding Stage III cam timing as I don't know if the grind has any timing mods relative to crank dead center positions. I'm guessing it's the same as stock, but prefer not to guess. So, need some expert assistance.
Also need other weight info as highlighted in yellow.
Old 12-08-2010   #2
Pete
Pete's Avatar
Default Re: Need Technical Data; cam timing, balancing, etc.
It won't let me write in the yellow so i wrote on the white.
Inlet opening primary & secondary 32
Inlet closing primary & secondary 80
Exhaust opening primary & secondary 80
Exhaust closing primary & secondary 32
Above would be set at 114.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-08-2010   #3
tpepmeie
Pete
292 degrees seat duration? I didn't think Stage III's were that large. I had 283 or 285 degrees in my head for some reason. Has anybody actually measured these? I am glad Jerry is asking, because seat duration is the important figure impacting performance of the cams. 0.050" is nice to know, and how they are advertised, but lots of intake / exhaust flow happens from zero to .050.
Seat duration, for hydraulic lifter cams, is usually measured at 0.004" lobe lift to account for some lifter deflection.
Todd
Old 12-08-2010   #4
Pete
Pete's Avatar
Todd, i was just doing an estimate of what it is.
If at 285 i would minus 3 degrees on either side.
I will have the Stage III's measured,i know i had the Stage II's checked i just don't remember what they were i have the info somewhere.
Todd,do you remember what the Stage II's were? that might give some insight.
Jerry,can i ask you why the interest on cams.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 12-12-2010   #5
Pete, Todd & Ryan,
Thanks for chiming in in this. I can't think of any better guys to call on!
Pete,
The info is for bearing load calculations.
Any idea when you might get the Stage III cams measured?
Old 12-12-2010   #6
tpepmeie
Jerry,
I weighed up a stock 90 bottom end parts. The pistons actually came it at an average 710g, but close enough to your figure. Range was 708-713.5g.
I had in my notes around 538g for rotating weight on the rods. I didn't measure it, though, so can't be sure where I got that from. Probably took the % from a prototype lotus build sheet I saw. Should get you pretty close. That includes the bolts.
Old 12-12-2010   #7
Originally Posted by tpepmeie View Post
Jerry,
My sampling of bare piston weight:
"A" pistons @ 483~487gr, avg of 484gr
"B" pistons @ 479~483gr, avg of 482gr (2gr lighter)
Pins, retainers & rings are much more consistent, so the variance probably comes down to the bare piston and the basis GM used for sorting pistons in "A" & "B" groups.
Much needed info Todd. Thanks!
Old 12-13-2010   #8
flyin ryan
flyin ryan's Avatar
I'll use the spread between 'Seat' & '.050"' to sometimes gauge how aggresive a cam is...Or at the same time, lazy. How much overlap & how much cylinder pressure may be staying in the chamber or being lost. Still doesn't beat measuring, but if you only have a cam card to look at it can help give a guy a little of the characteristic's of a particular cam grind.
Old 12-13-2010   #9
This is some information I dug up out of my files. I don't have any reference point for valve seat/opening, but from the short durations, I would imagine 0.050".
Stock Cams
Intake .214 .229 .389 .389
Exhaust .214 .214 .389 .389
SGC Cams
Stage I .228 .228 .415 .415
Stage II .237 .237 .440 .440
Stage III .242 .242 .450 .450
LPE Cams
A Cams
Intake .221 .236 .399 .445
Exhaust .221 .221 .399 .399
B Cams
Intake .239 .239 .445 .445
C Cams
Exhaust .239 .239 .445 .445
Old 12-13-2010   #10
Pete
Pete's Avatar
Stock Cams
SGC Cams
LPE Cams
A Cams
B Cams
C Cams
Looks about right Jerry
I would like to know the power difference between LPE B and C cams.
I have tested SGC Stg II's In & Ex replaced exhaust with a .224 .420 picked up 25RWHP,i'm starting to think we don't need more then .225-+ exhaust cam.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
