Old 11-17-2009   #1
Default Coilover Spring rates
So I did the Coilovers on the front of my car in June of this year. When I installed them I did 425# springs
I am getting ready to order the rest of my parts for the rear conversion, but what is a good spring rate??
I was thinking of 300# or 275# but what is the benefit of either?
Old 11-18-2009   #2
Default Re: Coilover Spring rates
I would like to know as well.
Old 11-18-2009   #3
According to Doug Rippie, 300# will be too stiff and he recommends 275#
they use 450# or 400# for the front, I am running 425# and like that so far
Coilovers for the rear got moved to the backburner again due to other issues that have come up
Old 11-18-2009   #4
I hear that
Thanks for the research I remember Ron talking about the buckboard rear springs he had setup so I was wondering
Old 11-18-2009   #5
Aurora40
Aurora40's Avatar
Marc H suggested to me to use 425/300 springs for my car. My criteria was I wanted tour to be more like sport, sport more like perf, and perf to be a little on the rough side for the street. Currently I drive in perf all the time except short bits where I know there are rough patches. I'd like to drive in sport all the time.
I've never installed them though, so I don't know. Looking at the leafspring rates, 300 is less than the Z51 rear rates, and above the base rate. 425 front is more like the '92+ cars that had softened front spring rates (even the Z07/Z51 cars). I don't want softer fronts, so if I ever did install them I'd go much stiffer front like 5-600.
Did you have to relocate the sway bar to do the fronts?
Old 11-18-2009   #6
yes I had to relocate the front bar. I when with 425 as Rippie suggests 400-450. I did not want too hard or too soft, to mee it feels like 425 is harder then my OEM 90 spring..
rear is still OEM and since I still have time I need to thin about the 275 vs 300 a little more.
For me with the leafs or the front coils I drive in sport mostly
Old 11-18-2009   #7
Aurora40
Aurora40's Avatar
That's interesting. I wonder if something is missing from the equation. Presumably a coil spring of the same rate would be softer, because the coil is not straight up and down. So the spring compresses less than the suspension travel.
A stock '90 ZR-1 has a 96.2 N/mm spring, which is ~550 lbs/in.
The Z51 rate was 660 lbs/in.
The '92+ Z was 430 lbs/in.
So I'd think a 425 coil spring would be softer than the later cars. People who install coil-overs though do not seem to go to those sort of extreme rates in the 550+ range. Which is why it seems like the math must be more complex than that or something?
Old 11-18-2009   #8
I don't know, but I remember talk of the calculations like this on CF.. about a year ago and I made note then that the 425 was my best choice for me to try..
I will see if I can find it again
Old 11-18-2009   #9
Post by Glass Slipper on CF in this Thread http://forums.*************.com/c4-z...g-the-fx3.html
The quote refers to rkreigh who is using 400 front/ 250 rear according to the link above
Originally Posted by glass slipper
You're welcome, glad it worked out for you.:thumbs:
To address your spring rate question, the stock spring rates for the '90-'91 ZR-1 is 549 LBs/inch front and 228 LBs/inch rear while the '92-'93 ZR-1 is 430 and 188 front and rear. Of course those are the spring rates, not the wheel rates which are affected by the mounting position of the spring on the suspension relative to the center of the wheel and the angle at which the force of the spring is exerted to the suspension. Wheel rates are always lower than spring rates on the C4.
As you can see, comparing spring rates of the coilovers to the leaf is an apples to oranges proposition...you really need the wheel rates to make a direct comparison, but let's try anyway.
For the front, the coilover mounts farther outboard on the lower control arm than the leaf giving it a higher wheel rate for the same spring rate. But the coilover is mounted at an angle meaning part of its' force has a horizontal component while the leaf exerts its' force in a pure vertical direction, this gives the coilover a lower wheel rate for the same spring rate. Without running the numbers, I'm going to call it a wash and say the spring rates can be compared directly although I suspect the coilover results in a slightly higher wheel rate. That being said, your present setup of 400 LB/inch is very close to the '92-'95 ZR-1s.
For the rear, the coilover mounts farther inboard by a small amount and is at a slight angle which gives the coilover a lower wheel rate for the same spring rate. But the long lower lateral link (minimizes the affect of the slightly inboard mount) and the low angle to vertical of the coilover results in just slightly lower wheel rates. Again, I haven't run the numbers, but we know for sure which direction it goes. That being said, your present setup of 250 LB/inch is very close to the '90-'91 ZR-1s.
Something else to consider is the horizontal component of force the coilover exerts on the suspension. On the rear, it's minimal and probably doesn't cause enough impact to be detected by the driver. On the front, the angle is enough to result in a horizontal force sufficient to compress the lower control arm bushing in the horizontal direction a measurable amount. When cornering, this causes an increase in compliance understeer that is sometimes confused as "slop" by the driver as the lower control arm on the outside of a turn compresses the bushing an amount equal to a factory setup plus the amount that the coilover caused. Because the tie rod connects to the front of the spindle (referred to as "front steer"), this action results in excessive "toe-out" on turn-in. That's actually a good thing since the factory setup exhibits compliance understeer also, but you get too much of a good thing and the car doesn't handle as well. Of course on a race car, they have solid steel bushings/heim joints meaning this is of no concern to them. Once again though, what works on the race track doesn't really work so well on the street unless you're willing to make some big sacrifices...which you don't seem so willing to do at this point. Obviously, poly bushings will significantly reduce the impact of coilovers to compliance understeer returning the handling back to "normal"...again at the sacrifice to ride quality.
You're so close to the factory spring rates, my recommendation would be to go back to the factory springs and make improvements via shocks, stabilizer bars, alignment, and tires. The factory front spring has the added benefit of additional roll resistance via the dual mount design. This is often incorrectly referred to as "crosstalk" in a negative connotation, but it was a novel way of increasing roll resistance without increasing spring rates giving a softer ride. It worked so well, GM added it to the rear suspension of the C5 which is why your C5 rides so much better than your C4 while handling better. A sticky autocross tire like the Kumho V700s have a tread depth of 6/32" and will last for 2-3 years at the rate we drive these cars, you'll be amazed at their grip. Learn to do alignments yourself so you can go back and forth from an agressive autocross alignment to a street alignment...it's really easy once you learn and the C4s are the absolute easiest because of the front steer arrangement and the adjustments being made on the upper control arm. All you do is add/pull shims once you optimize either the race or street alignment you want. Just pick which one you want to optimize and you can get very close to other by just doing the shims. I optimize the race setting and live with a little wear on the street. I can literally go from race to street in less than 20 minutes at the track.
If you really want to lower it, stick to the '90-'91 ZR-1 springs or get some '88-'91 Z51 springs...the lower you go, the stiffer the spring has to be to keep you from hitting the bump stops on big bumps. Once you get to the bump stops, spring rate goes to infinity...not a good thing for handling or ride. One other thought to consider, when you lower the car, you change the "z" and "d" heights of the front and rear suspensions which takes the suspension out of the optimum position for the camber curves as the suspension goes through its' travel. If all you're after is the "look", then it's no big deal. If you have super stiff springs that limit wheel travel anyway, again it's no big deal. And one last thing...as you lower the car, you increase anti-dive in the front suspension and decrease anti-squat in the rear suspension. Your C5 gets increased anti-dive and anti-squat as you lower it...it's just geometry.
Old 11-18-2009   #10
More:
http://forums.*************.com/c4-z...r-shock-s.html
