Old 02-23-2008   #1
becktom
Default Software to change speedometer signal
Does anybody has a software or know how to change the original set-up of the signal which runs from the transmission to the ECM/CCM?
As I've changed my rear end to another ratio, I'll need to modify my present system for correct MPH reading.
I know there are some additional convertors/gear sets on the market, but I would prefer to alter the existing software if possible.
If somebody might have an idea, would be great!
Thanks
Thomas
becktom is offline   Reply With Quote
Old 02-23-2008   #2
Jeffvette
Default Re: Software to change speedometer signal
Only thing that is available is the speedo correction box, which you splice into the existing wires and program it.
Old 02-24-2008   #3
becktom
Thanks Jeff,
could you recommend any supplier/manufacture or doesn't matter?
Thanks
Thomas
Old 02-24-2008   #4
Jeffvette
http://www.cyberdynegauges.net
Old 03-25-2010   #5
Ccmano
Sorry to dig up this old thread...
My question is to Jeff,
Have you used the Cyberdyne box? If so how well did it work? I just changed to 4.10 gears and bought a Cyberdyne box. When I hook it up, the speedo just sits there at zero and eventually the "service engine soon" light comes on. When I remove the box all is OK. I'm calling Cyberdyne in the morning.
Any thoughts?
H
Old 03-25-2010   #6
Why wouldn't you change speedo gear in trans?
When I installed a ZF-6 in my 84, I also used 3.45 gears in rear. Just need right combo of drive and ring gear.
Old 03-25-2010   #7
I would get the gears from Haibeck.. for the trans and be done
Old 03-25-2010   #8
Ccmano
Gears are $120 from Haibeck not to mention the labor involved. The Cyberdyne calibration box was $49 and is precisely adjustable. (assuming I can get it working)
H
Old 03-26-2010   #9
jonszr1
jonszr1's Avatar
you might give bill boudreau a call he did one for me on my white car when we did the clutch and tranny .
