Old 10-11-2005   #1
haber rj
Default Looking for 5 spokes
Would anyone know where I could find a set of 5 spoke ZR1 wheels, or the best place to buy a set of new ones. I am heading to Florida in a month for 3 weeks, any help would be appreciated.
haber rj
haber rj is offline   Reply With Quote
Old 10-11-2005   #2
zr1mom
zr1mom's Avatar
Default Re: Looking for 5 spokes
Actually these are easy to find, try GM, or Mid America, Ecklers or Corvette Mike.
They have them plain and in Chrome. Remember there are two types out there. The OEM ones from GM are made in Japan. If they are not made in Japan then they are after market look a likes.
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 10-11-2005   #3
Chris
Do orginal 94 -95 spokes have a part number associated? Hw can you tell if Original verses others? Beside if they are chrome.
Chris is offline   Reply With Quote
Old 10-11-2005   #4
zr1mom
zr1mom's Avatar
The quickest is just to look inside for Japan.
The GM part numbers are:
10214046 17x9.5 Front
12512904 17x11 Rear
ZR-1 Mom
Founder ZR-1 Net
Old 10-12-2005   #5
Chris
The part numbers on mine are
Fronts 10214046 and another code AFR
Rears 10214047 and another code AFS
Did they date code these rims?
Old 10-12-2005   #6
haber rj
Mom thank you for the valuable information, with these part numbers I can go to my GM dealer and order them. I have inquired serveral times up here and the same question is asked by all the parts guys, what's the back spacing, I should have known better, they couldn't even change my oil at the dealership, they didn't know how. I will also give Mid America a call and I heard that Corvette Central in Michigan is also a good place to deal. I will update on my progress,
haber rj
Old 10-12-2005   #7
Chris
MOM- re-check your part numbers on the rear ZR1 rims.
Old 10-13-2005   #8
mrzzzr1
mrzzzr1's Avatar
Question Re: Looking for 5 spokes
What is the correct offset for 5 spoke aftermarket ZR1 wheels (for a 90 ZR1).
Manufacturers list 38, 50 and 56 mm.
Also I was told the measurement is taken from the centerline of the wheel width to the actual hub mounting face. Can anyone confirm this?
mrzzzr1 is offline   Reply With Quote
Old 10-25-2005   #9
A1990
A1990's Avatar
50mm front and 36mm rear. 56mm is GS offset
Dennis Fierstein
90 ZR-1 #2562 Atomic-Z
ZR-1 Net Registry Treasurer
Old 10-25-2005   #10
Patton
Patton's Avatar
Hey, try P&G Chevy. Trust me, they are the cheapest for ANY OEM part... At least with my experience so far. MUCH cheaper. Havent doen the homework on wheels yet. I freakin love the 5 spokes, If I wasnt lucky enough to find a '94 I would have bought a set by now.
They have part numbers listed as
$420.49 for A front
$396.68 for A rear.
https://www.partszoneonline.com
Patton is offline   Reply With Quote
