Old 07-15-2024   #1
ZuggZR1
ZuggZR1's Avatar
Default 1990 3rd brake light bulb replacement
What bulb is it and how do you remove it to replace a burnt out bulb? Don't find in my service manual.
Sent from my SM-S908U1 using ZR-1 Net Registry mobile app
George Zugg
1990 DRM 500 ZR1
build#952
[SIGPIC][/SIGPIC]
ZuggZR1 is offline   Reply With Quote
Old 07-15-2024   #2
scorp508
Default Re: 1990 3rd brake light bulb replacement
891 or I believe a G4 bulb also works.
Open the hatch.
Remove two torx bolts from underneath.
Flip the now free light housing over.
Remove two Phillips screws to open housing.
Swap bulbs. Use gloves, so the oil on your hands doesn't get on the new halogen bulbs.
When reassembling make sure the lip of the rubber gasket is outside the light housing. The housing kind of sits "inside" the outer lip of the gasket.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite, 310 RWHP 350ck L98
1994: ZR-1 #150, Admiral Blue / Black, 445 RWHP 350ci LT5
2015: Z06 Coupe, Z07, M7, Arctic White / Red, Stock LT4
scorp508 is offline   Reply With Quote
Old 07-15-2024   #3
ZuggZR1
ZuggZR1's Avatar
Thanks. I will do that. Do u know what bulb that it?
George Zugg
1990 DRM 500 ZR1
build#952
[SIGPIC][/SIGPIC]
Old 07-15-2024   #4
scorp508
891 (10W) bulbs or G4 (10W) bulbs. The LED equivalent are only around 2-3W.
Examples...
https://a.co/d/7QuB0ke
https://a.co/d/0OIrMIl
Old 07-15-2024   #5
Go slow or the thin gasket from the light lens to the housing will tear.
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 07-15-2024   #6
ZuggZR1
ZuggZR1's Avatar
Thank you Steve I will definitely make note of that
George Zugg
1990 DRM 500 ZR1
build#952
[SIGPIC][/SIGPIC]
Old 07-15-2024   #7
scorp508
A couple photos from today while I was attempting to put LED G4 bulbs in. They didn't work as the base was too thick to fit into the housing. I have another style another ZR-1 owner successfully used now on the way.
The two T-30 bolts in the middle you need to first remove. There isn't much space, so a 1/4" drive T-30 socket if you have one works better than a 3/8" drive socket. I only have 3/8" drive in that size, so I start them then use my fingers to back them out.
