Old 06-18-2024   #1
bmarcum
Default Best sounding cams
So I am dreaming of what my next z should be. I remember some (not a lot) of C4 Zr-1 that had high over lap cams and sound great at idle and at 7,000. I couldn't find the YouTube videos. Anyone have good sound videos of their or others cammed Z's? Also I never driven a cammed Z. How the power curve/drivability.
bmarcum is offline   Reply With Quote
Old 06-18-2024   #2
1991 Corvette ZR-1
Default Re: Best sounding cams
I have been thinking about this lately as well. Although in most cases, I believe heads are ported along with the cams. I have everything opened up, but the heads. The idea of the changed idle with cams and the shifted power range is still intriguing.
I hate to not try it if I already had the engine out of the car and cam covers off, but it is probably a cart before the horse idea, without ported heads.
Old 06-19-2024   #3
Stage 1 Dr. Greekenstein cams, fully ported, headers, Xpipe, Magnaflow muffs w C6 Z06 NPP valves.
https://youtu.be/LYgBSTyLd9I?si=MGVLn-aDQA3kmJEn
Old 06-19-2024   #4
tpepmeie
255/244 .500/.450 lift sound pretty nasty
Old 06-23-2024   #5
bmarcum
The only thing I don't love about LT5 vs SBC is the amazing noises a high compression wide duration cam sounds on a SBC. Just curious about similar duration on LT5. Thanks @xfireZ51. Sounds good. Any revs or runs?
Also is that still 350 CID?
Old 06-23-2024   #6
The sound of a cammed SBC is due to the necessity for high lift/ long duration to get the breathing. 4 valves do that for the LT5, so cam profile can be relatively mild in comparison for similar or better performance.
Yes its a stock block 5.7L. Dyno?d at 454rwhp@6875rpm and 402rwtq@5300rpm.
Old 06-23-2024   #7
bmarcum
WOW 454rwhp nicely done! I bet that is a ball. is that the car on your YouTube post?
Old 06-23-2024   #8
Yes it is. The video was b4 tuning. Makes u think of what GM could have done continuing to develop that platform. Its the way it should have come from the factory.
Old 06-24-2024   #9
bmarcum
I couldn't find Stage 1 Dr. Greekenstein cams are they pepmeierengines.com cams? Or are they Pete the greeks? I remember reading about Pete work sometime ago?
Old 06-24-2024   #10
Dr. Greekenstein is my name for Pete ZR-1 work.
