Old 08-06-2022   #1
dandt67
Default FS - ZR-1 Fuel Injectors
LT5 FIC Factory Re-manufactured ZR-1 Delphi Stainless Steel Injectors (made in USA). 100% alcohol compliant with all stainless internals.
The Tops are the same size and look as the GM OEM, and the bottoms are polished just like the factory OEM units.
Injectors have been factory ultrasonic cleaned, electrically tested, leak tested, spray pattern tested, reassembled with all new parts, flow tested/matched, and vac sealed with all test results included.
$420 plus shipping for 16 injectors with ?O? ring primary seals for 1993-1995. Would need primary seals from Jerry Gaskets for 1990-1992 applications.
Can bring to Corvette Carlisle.
dandt67
1991 ZR-1 Quasar Blue #1470
2016 Z06/Z07 Long Beach Red Tintcoat
dandt67 is offline   Reply With Quote
