Old 06-15-2017   #1
cloudshe
Default 1995 OEM Fuel Injectors
I've been told by a potential buyer that my 55k mile '95 ZR will obviously need its fuel injectors replaced, it's just a matter of time. He said that this is what an experienced ZR-1 mechanic told him
Since this is not what i've heard about the post-'92 injectors, i'm wondering if this concern is real. the ZR has been well cared for, never raced, no indications of running at anything less that 100%
Appreciate any comments!
cloudshe is offline   Reply With Quote
Old 06-15-2017   #2
conesare2seconds
Default Re: 1995 OEM Fuel Injectors
It is doubtful you'll ever need to replace a '95s injectors, I think.
Old 06-15-2017   #3
rush91
The 90-92 injectors were not compatible with the ethanol in todays gasoline. The 93-95 injectors are compatible and you should be just fine....I believe Haibeck changed mine out twice. Last time with 93-95 injectors and no problem since.
Old 06-15-2017   #4
As said, the 93-95 injectors are not susceptible to alcohol. However, a good replacement for 90-95 injectors is the Accel 150821s from Summit, IF FIC doesn't have any on hand.
Old 06-15-2017   #5
Roadster
Roadster's Avatar
When the plenum pull was done in January, I decided to change them out while I was in there. Not something you have or need to do with a 94, unless there is a problem.
As I mentioned back then...
"My injectors were original, and they all tested out between 12.2 and 12.5
They were still good. But I took advantage of a sale through an email on FIC and went with new"
Very happy with the results, just need to wrap up the current plenum pull asap....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 06-15-2017   #6
90-92 injectors can't take the ethanol in todays fuels. 93-95's will be fine with todays fuel. But bear in mind that todays 10%+ ethanol fuels go bad quickly. If the 93-95 or even FIC injected car isn't used regularly additives should be used to prolong the fuels life. Just my experience
Old 06-15-2017   #7
I've seen later cars fail too. I don't consider any of then resistant and need changed
Old 06-16-2017   #8
PhillipsLT5
PhillipsLT5's Avatar
I like my accells but I think Jerry may have a FIC kit available
Old 06-16-2017   #9
Whatever you buy make sure these are stainless steel sleeved. Both my RC's in my 91 and my FIC's in my 90 are so rust is not an issue. GC
Old 06-16-2017   #10
My Accels have been in the motor for 10 years now. No hiccups.
